error message - device with APC40MK2
orolights
2014-11-17 23:00:54
MACBook Pro Retina mid 2012
OS X 10.10 Yosemite
Bomes v1.7.2
Akai APC40 MK2
(Uses Resolume Arena 4.1.11 Just for an overall knowledge)
getting this error msg of selecting another device
any advices?
Screen Shot 2014-11-17 at 23.49.31.png (28.11 KiB) Viewed 4094 times
DvlsAdvct
2014-11-17 23:07:08
Hi orolights
Is Resolume connected to the APC40 as well as Bome MIDI Translator?
Jared
orolights
2014-11-18 00:17:53
Hi Jared
you know... you got me little confused there :wink:
i double checked all my options, with or without Resolume, with resolume in all combinations of in/out, always getting this err msg.
somehow i'm starting to think it just might be not supported yet by Bomes (sayin this with careful tone)
DvlsAdvct wrote:Hi orolights
Jared
DvlsAdvct
2014-11-20 04:27:44
Both Resolume and the APC40 are supported by Bome MIDI Translator.
We need to isolate the problem so we can work to fix it. If everything is closed (Resolume, BMT) and the APC40 is disconnected I want you to do the following:
Connect the APC40
Activate Bome MIDI Translator
Do you receive the error?
orolights
2014-11-21 12:08:05
problem fixed.
post can be closed
DvlsAdvct
2014-11-22 00:54:06
Can you let us know what fixed it in case other users are searching?
Jared
orolights
2014-11-23 19:01:11
I needed to do a full restart for all my devices after i plugged off the APC40 and plugged in the MK2 (have them both)
