Only Changing Colour On/Off States on APC40 MK2
ElRayo
2014-11-20 14:03:10
Greetings,
We recently bought the APC40 MK2 for controlling Resolume. We like the layout and all the functions; we don't have to remap anything. However we would love to adjust it's ON & OFF states of the buttons. I've been already thinkering with it and I'm able to get all the colours etc etc. However I encountered one problem which is a pain and a bottleneck atm. I'll give an Exampe:
I need a button that needs to be full colour RED in the -off- state and white in the -on- state (Note On/Off).
So I created the following translations;
RED On 90 20 7F ---> 90 20 10
RED Off 80 20 00 ---> 90 20 05 (I tried 80 20 05 aswell but that obvously doesn't work)
This obviously creates the problem that when I press a button the APC does exactly what I want, however it keeps sending ON to Resolume (which eventually crashes). Sadly after many tries I'm unable to find a solution for this.
TL:DR; How can I change the On and Off State of my push buttons on my apc40 mk2 without changing their functions?
DvlsAdvct
2014-11-22 00:51:15
Hi ElRayo
I'm assuming all of your translators for the outputs to the APC40 are in their own preset.
Can you change the Default MIDI Ports of that Preset to IN - APC40 and OUT - APC40?
That should stop sending the messages to Resolume. Let me know if that works.
Jared
ElRayo
2014-11-22 01:01:47
I'll check it Monday when I'm back at work.
ElRayo
2014-11-24 11:32:13
DvlsAdvct wrote:Hi ElRayo
Jared
It indeed stops sending messages to Resolume and the APC does have it's colour functions. What is the next step?
DvlsAdvct
2014-11-24 16:41:47
In the MIDI Router, can you draw a line from the APC40 to the virtual port connected to Resolume? Does that work?
