DJKCRAY
2014-11-24 21:03:47
I have the new ohmRGB I want to use it with Resolume and have the feedback work with the clip lights, layer select, and ect. . After all my reading people seem to be using Bome to translate the midi info from resolume. I have seen a set up with the old Ohm64 by user Tschoepler but that is not working with my RGB. The livid editor has also changed since his videos are made in 2010. I am a noob to midi editing and frankly not very good at coding.
If anyone has any links, patches, or more info please let me know!!
I have the latest Macbook Pro running osx 10.9.5, Resolume 4.1.11, and brand new OHMrgb.
DvlsAdvct
2014-11-25 00:35:58
If you can't find any projects around the forums I can definitely walk you through getting to where you need to be. The learning curve can be steep, but once you get over it there's a whole lot you can manage to do yourself.
Jared
DJKCRAY
2014-11-25 00:39:15
Yes jarad i wod love a walk through. I have not found any templets yet. It does suprise me very much as this is a popular controller
DvlsAdvct
2014-11-25 00:41:39
I'm surprised there aren't any templates tying the Ohm64 directly to Resolume. I can contact Livid directly but if the internet doesn't show anything then it isn't likely to be there. Do you own MIDI Translator Pro?
Jared
DJKCRAY
2014-11-25 00:43:39
I have downloaded the demos, i didnt want to purchase untill i found out more info
DvlsAdvct
2014-11-25 00:44:21
Well, what is it you want to do? Can you provide a little more detail?
DJKCRAY
2014-11-25 01:44:56
I have downloaded his patch software he uses called max. When i open his files i get no controller found, i have changed all the ports in the settings also.
- max screenshot
- Screen Shot 2014-11-24 at 4.41.43 PM.png (112.79 KiB) Viewed 6134 times
DvlsAdvct
2014-11-25 21:25:45
I have no idea how to trouble shoot his application since I don't have an Ohm64. We can try and recreate a lot of the MIDI feedback in MT but it'll be very different than what he put together.
