303Dan
2014-12-02 01:07:31
Hello,
I'm trying to create some translators to trigger certain key command shortcuts in Pro Tools.
Anything I create that does NOT include the "Alt" and "Start" or "Windows" key, works fine.
When I create a translator that outputs what is supposed to be a key down event with Alt or Start, then some other key, then a key up even for that Alt or Start, it doesn't work. The Midi Translator Log is showing the output as intended.
I notice when I'm in Pro Tools that when I trigger the translator containing "Alt", via MIDI, the focus seems to jump from the Edit Window up to the Main Window and focuses on the menu system. When I press the Alt key on my keyboard when I'm in Pro Tools, that does not happen. The menus do not get focus.
Any ideas?
Any ideas?
