sevaels
2014-12-14 19:54:15
Hey Guys,
I have no idea what I messed up, but I'm fairly sure its my fault.
I installed Bome's translators to use with Cubase for key shortcuts. Then someone here posted about using TouchOSC and Cubase's generic MIDI device. Turns out that seemed to be the best way to communicate directly to Cubase.
I tried uninstalling Bome's MIDI Translator and I probably went too far...
Now I can't get any virtual midi ports to show up in Cubase, Kontakt, Sibelius etc. This includes TouchOSC Bridge (Which I now know uses your brilliant driver) and MT.
When I open up MT and go to 'Setup MIDI Devices and Port Aliases' and click on one of the virtual ports I get the following error:
Error Opening virtual MIDI OUT device "Bome's Midi Translator 1 Virtual Out": port does not exist
This is most likely due to me manually deleting files with 'bome' in it, not realizing that TouchOSC Bridge uses the driver to run as well.
I've tried uninstalling and re-installing both TouchOSC Bridge and MT, along with restarts. I'm running Windows 8.1
Now when I launch MT it says:
Failed to open MIDI IN device "Bome's Midi Translator 1 Virtual In".
Please connect the device(s) or select another one in the MIDI setup.
I tried re-installing MT using 'Force re-install MIDI driver' and I got the error:
Error uninstalling Bome's Virtual MIDI driver support:
Uninstalling the bus driver failed with error code: 15
After completing the installation, I tried the force re-install driver again and here's what I get:
Cannot copy bmidilib.dll to C:\Windows\system32\bmidilib.dll
I also have no idea if this is normal, but each time it seems a virtual midi port is launched (either through MT or TouchOSC Bridge) my Windows system makes the same sound I get when I mount a USB drive. I should also tell you that I do see 'Bome Software-Bome's MIDI port 01' and 02 in Device Manager under 'Other Devices'. They seem to have no driver associated.
Any help would be really appreciated.
