blow
2014-12-20 20:09:59
Hello, ive been sent here from Serato.com i was told that using the Bome Midi Translator software, i could turn on the led lights on my Novation Dicers for when im using the shift mode that you can map buttons to. Is that correct?
When you map buttons from Serato DJ to the spare banks on the Dicers the buttons are blank, they dont light up.
I just want add the led lights for when i trigger samples/effects.
Has anyone done it to the dicers or is it even possible, if it is could i get some help doing it.
