Abk123
2015-01-01 10:22:28
The program doesn't open. Please, help to repair. Thank you.
Log is here:
Log is here:
Process: MidiTranslatorPro [583]
Path: /Applications/Bome's Midi Translator Pro.app/Contents/MacOS/MidiTranslatorPro
Identifier: com.bome.miditranslator.pro
Version: 1.7.2 (511)
Code Type: X86 (Native)
Parent Process: ??? [1]
Responsible: MidiTranslatorPro [583]
User ID: 501
Date/Time: 2015-01-01 12:06:44.507 +0300
OS Version: Mac OS X 10.10.1 (14B25)
Report Version: 11
Anonymous UUID: 98F0B09E-102E-AA3A-AD93-10087FD103A7
Time Awake Since Boot: 460 seconds
Crashed Thread: 35 Java: AWT-EventQueue-0
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Dyld Error Message:
Symbol not found: _CGContextSetAllowsAcceleration
Referenced from: /Library/Java/JavaVirtualMachines/1.6.0_37-b06-434.jdk/Contents/Libraries/libawt.jnilib
Expected in: /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
Thread 0:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x94469a2e mach_msg_trap + 10
1 libsystem_kernel.dylib 0x94468ad0 mach_msg + 68
2 com.apple.CoreFoundation 0x975afae6 __CFRunLoopServiceMachPort + 214
3 com.apple.CoreFoundation 0x975aeef9 __CFRunLoopRun + 1529
4 com.apple.CoreFoundation 0x975ae696 CFRunLoopRunSpecific + 390
5 com.apple.CoreFoundation 0x975ae4fb CFRunLoopRunInMode + 123
6 com.apple.HIToolbox 0x91017178 RunCurrentEventLoopInMode + 262
7 com.apple.HIToolbox 0x91016eb1 ReceiveNextEventCommon + 494
8 com.apple.HIToolbox 0x91016cac _BlockUntilNextEventMatchingListInModeWithFilter + 99
9 com.apple.AppKit 0x97a0fd99 _DPSNextEvent + 734
10 com.apple.AppKit 0x97a0f5e1 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 186
11 libawt.jnilib 0x18004241 -[NSApplicationAWT nextEventMatchingMask:untilDate:inMode:dequeue:] + 132
12 com.apple.AppKit 0x97a01dac -[NSApplication run] + 907
13 libawt.jnilib 0x18002564 +[AWTStarter startAWT:] + 2019
14 libawt.jnilib 0x18001d31 -[CPerformer perform] + 259
15 libobjc.A.dylib 0x96715853 -[NSObject performSelector:withObject:] + 70
16 com.apple.Foundation 0x9b6ce91c __NSThreadPerformPerform + 389
17 com.apple.CoreFoundation 0x975bdd1f __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 15
18 com.apple.CoreFoundation 0x975af7ad __CFRunLoopDoSources0 + 253
19 com.apple.CoreFoundation 0x975aece2 __CFRunLoopRun + 994
20 com.apple.CoreFoundation 0x975ae696 CFRunLoopRunSpecific + 390
21 com.apple.CoreFoundation 0x975ae4fb CFRunLoopRunInMode + 123
22 com.apple.JavaApplicationLauncher 0x00008c17 startupJava(LauncherArgsStruct*) + 309
23 com.apple.JavaApplicationLauncher 0x0000bc51 launchJavaApplicationWithJVMInfo + 1381
24 com.apple.JavaApplicationLauncher 0x0000835f launchJavaApplication + 39
25 com.bome.miditranslator.pro 0x00001e36 0x1000 + 3638
26 com.bome.miditranslator.pro 0x00001c5b 0x1000 + 3163
27 com.bome.miditranslator.pro 0x00001b89 0x1000 + 2953
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x944708d2 kevent64 + 10
1 libdispatch.dylib 0x95a0873f _dispatch_mgr_invoke + 245
2 libdispatch.dylib 0x95a083a2 _dispatch_mgr_thread + 52
Thread 2:
0 libsystem_kernel.dylib 0x9446fe6e __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x9211336d _pthread_wqthread + 939
2 libsystem_pthread.dylib 0x92110eea start_wqthread + 30
Thread 3:
Thread 4:
Thread 5:
Thread 6:
2 libjvm.dylib 0x06688c16 0x6674000 + 85014
3 libjvm.dylib 0x06688b52 0x6674000 + 84818
4 libjvm.dylib 0x06688a18 0x6674000 + 84504
5 libjvm.dylib 0x0668855d 0x6674000 + 83293
6 libjvm.dylib 0x0668834d 0x6674000 + 82765
7 libjvm.dylib 0x06748d76 0x6674000 + 871798
8 libjvm.dylib 0x06748603 0x6674000 + 869891
9 com.apple.JavaApplicationLauncher 0x0000adce startJavaApplication + 8494
10 com.apple.JavaApplicationLauncher 0x00008c9a runJava(LauncherArgsStruct*) + 76
11 com.apple.JavaApplicationLauncher 0x00008c46 java_main_stub(void*) + 17
12 libsystem_pthread.dylib 0x92112ecf _pthread_body + 138
13 libsystem_pthread.dylib 0x92112e45 _pthread_start + 162
14 libsystem_pthread.dylib 0x92110f0e thread_start + 34
Thread 7:: Java: Exception Handler Thread
2 libsystem_kernel.dylib 0x94469442 mach_msg_server + 415
3 libjvm.dylib 0x06689baa 0x6674000 + 89002
4 libjvm.dylib 0x06689a33 0x6674000 + 88627
5 libjvm.dylib 0x066884bc 0x6674000 + 83132
6 libsystem_pthread.dylib 0x92112ecf _pthread_body + 138
7 libsystem_pthread.dylib 0x92112e45 _pthread_start + 162
8 libsystem_pthread.dylib 0x92110f0e thread_start + 34
Thread 8:: Java: Gang worker#0 (Parallel GC Threads)
6 libjvm.dylib 0x066883e7 0x6674000 + 82919
7 libjvm.dylib 0x0669ff41 0x6674000 + 180033
8 libjvm.dylib 0x0669fe2b 0x6674000 + 179755
9 libjvm.dylib 0x066884bc 0x6674000 + 83132
10 libsystem_pthread.dylib 0x92112ecf _pthread_body + 138
11 libsystem_pthread.dylib 0x92112e45 _pthread_start + 162
12 libsystem_pthread.dylib 0x92110f0e thread_start + 34
Thread 9:: Java: Gang worker#1 (Parallel GC Threads)
Thread 10:: Java: Gang worker#2 (Parallel GC Threads)
Thread 11:: Java: Gang worker#3 (Parallel GC Threads)
Thread 12:: Java: Gang worker#4 (Parallel GC Threads)
Thread 13:: Java: Gang worker#5 (Parallel GC Threads)
Thread 14:: Java: Gang worker#6 (Parallel GC Threads)
Thread 15:: Java: Gang worker#7 (Parallel GC Threads)
Thread 16:: Java: Gang worker#0 (Parallel CMS Threads)
7 libjvm.dylib 0x06981a4e 0x6674000 + 3201614
Thread 17:: Java: Gang worker#1 (Parallel CMS Threads)
Thread 18:: Java: Concurrent Mark-Sweep GC Thread
2 libjvm.dylib 0x06688ce6 0x6674000 + 85222
3 libjvm.dylib 0x066a68a6 0x6674000 + 207014
4 libjvm.dylib 0x06688a34 0x6674000 + 84532
7 libjvm.dylib 0x067b17e5 0x6674000 + 1300453
8 libjvm.dylib 0x067b1753 0x6674000 + 1300307
9 libjvm.dylib 0x066a66c1 0x6674000 + 206529
10 libjvm.dylib 0x066884bc 0x6674000 + 83132
11 libsystem_pthread.dylib 0x92112ecf _pthread_body + 138
12 libsystem_pthread.dylib 0x92112e45 _pthread_start + 162
13 libsystem_pthread.dylib 0x92110f0e thread_start + 34
Thread 19:: Java: VM Thread
7 libjvm.dylib 0x06720d96 0x6674000 + 707990
8 libjvm.dylib 0x06720a3f 0x6674000 + 707135
Thread 20:: Java: Reference Handler
4 libjvm.dylib 0x0672f968 0x6674000 + 768360
5 libjvm.dylib 0x0672ee6a 0x6674000 + 765546
6 libjvm.dylib 0x0672eb5c JVM_MonitorWait + 203
7 libjvmlinkage.dylib 0x02500dd5 JVM_MonitorWait + 69
8 ??? 0x0800b9d9 0 + 134265305
9 ??? 0x08003e31 0 + 134233649
10 ??? 0x08003e31 0 + 134233649
11 ??? 0x08001374 0 + 134222708
12 libjvm.dylib 0x067220d3 0x6674000 + 712915
13 libjvm.dylib 0x06721e45 0x6674000 + 712261
14 libjvm.dylib 0x0672e80d 0x6674000 + 763917
15 libjvm.dylib 0x0672e69d 0x6674000 + 763549
16 libjvm.dylib 0x0672e61b 0x6674000 + 763419
17 libjvm.dylib 0x0672e475 0x6674000 + 762997
18 libjvm.dylib 0x0672e2b3 0x6674000 + 762547
19 libjvm.dylib 0x066884bc 0x6674000 + 83132
20 libsystem_pthread.dylib 0x92112ecf _pthread_body + 138
21 libsystem_pthread.dylib 0x92112e45 _pthread_start + 162
22 libsystem_pthread.dylib 0x92110f0e thread_start + 34
Thread 21:: Java: Finalizer
10 ??? 0x08003f97 0 + 134234007
11 ??? 0x08003f97 0 + 134234007
12 ??? 0x08001374 0 + 134222708
13 libjvm.dylib 0x067220d3 0x6674000 + 712915
14 libjvm.dylib 0x06721e45 0x6674000 + 712261
15 libjvm.dylib 0x0672e80d 0x6674000 + 763917
16 libjvm.dylib 0x0672e69d 0x6674000 + 763549
17 libjvm.dylib 0x0672e61b 0x6674000 + 763419
18 libjvm.dylib 0x0672e475 0x6674000 + 762997
19 libjvm.dylib 0x0672e2b3 0x6674000 + 762547
20 libjvm.dylib 0x066884bc 0x6674000 + 83132
21 libsystem_pthread.dylib 0x92112ecf _pthread_body + 138
22 libsystem_pthread.dylib 0x92112e45 _pthread_start + 162
23 libsystem_pthread.dylib 0x92110f0e thread_start + 34
Thread 22:: Java: Surrogate Locker Thread (Concurrent GC)
6 libjvm.dylib 0x0668832a 0x6674000 + 82730
7 libjvm.dylib 0x0673f7f4 0x6674000 + 833524
8 libjvm.dylib 0x0673f738 0x6674000 + 833336
9 libjvm.dylib 0x0672e475 0x6674000 + 762997
10 libjvm.dylib 0x0672e2b3 0x6674000 + 762547
11 libjvm.dylib 0x066884bc 0x6674000 + 83132
Thread 23:: Java: Signal Dispatcher
0 libsystem_kernel.dylib 0x94469a6a semaphore_wait_trap + 10
1 libjvm.dylib 0x067400da 0x6674000 + 835802
2 libjvm.dylib 0x0673fab8 0x6674000 + 834232
3 libjvm.dylib 0x0672e475 0x6674000 + 762997
4 libjvm.dylib 0x0672e2b3 0x6674000 + 762547
Thread 24:: Java: C1 CompilerThread0
7 libjvm.dylib 0x0674798a 0x6674000 + 866698
8 libjvm.dylib 0x067412b0 0x6674000 + 840368
9 libjvm.dylib 0x0674105a 0x6674000 + 839770
10 libjvm.dylib 0x0672e475 0x6674000 + 762997
11 libjvm.dylib 0x0672e2b3 0x6674000 + 762547
12 libjvm.dylib 0x066884bc 0x6674000 + 83132
13 libsystem_pthread.dylib 0x92112ecf _pthread_body + 138
14 libsystem_pthread.dylib 0x92112e45 _pthread_start + 162
15 libsystem_pthread.dylib 0x92110f0e thread_start + 34
Thread 25:: Java: Low Memory Detector
7 libjvm.dylib 0x06741f98 0x6674000 + 843672
Thread 26:: Java: VM Periodic Task Thread
4 libjvm.dylib 0x06744a39 0x6674000 + 854585
Thread 27:: Java: AWT-Shutdown
11 ??? 0x0800430d 0 + 134234893
Thread 28:
Thread 29:
Thread 30:
Thread 31:
Thread 32:
6 com.apple.AppKit 0x97b836b4 _NSEventThread + 283
7 libsystem_pthread.dylib 0x92112ecf _pthread_body + 138
8 libsystem_pthread.dylib 0x92112e45 _pthread_start + 162
9 libsystem_pthread.dylib 0x92110f0e thread_start + 34
Thread 33:: Java: Java2D Disposer
12 ??? 0x0800430d 0 + 134234893
13 ??? 0x08001374 0 + 134222708
14 libjvm.dylib 0x067220d3 0x6674000 + 712915
15 libjvm.dylib 0x06721e45 0x6674000 + 712261
16 libjvm.dylib 0x0672e80d 0x6674000 + 763917
17 libjvm.dylib 0x0672e69d 0x6674000 + 763549
18 libjvm.dylib 0x0672e61b 0x6674000 + 763419
19 libjvm.dylib 0x0672e475 0x6674000 + 762997
20 libjvm.dylib 0x0672e2b3 0x6674000 + 762547
21 libjvm.dylib 0x066884bc 0x6674000 + 83132
22 libsystem_pthread.dylib 0x92112ecf _pthread_body + 138
23 libsystem_pthread.dylib 0x92112e45 _pthread_start + 162
24 libsystem_pthread.dylib 0x92110f0e thread_start + 34
Thread 34:: Java: Image Fetcher 0
4 libjvm.dylib 0x0672f983 0x6674000 + 768387
11 ??? 0x08003e31 0 + 134233649
Thread 35 Crashed:: Java: AWT-EventQueue-0
0 dyld 0x8fea9085 dyld_fatal_error + 1
1 dyld 0x8feac111 dyld::fastBindLazySymbol(ImageLoader**, unsigned long) + 184
2 libdyld.dylib 0x98c9946c dyld_stub_binder_ + 20
3 libawt.jnilib 0x180173d1 -[AWTDrawableContext _createGraphicsIfNeeded] + 377
4 libawt.jnilib 0x1801724f -[AWTDrawableContext beginCG] + 40
5 libawt.jnilib 0x1801715c -[AWTDrawableContextManager getContext:canDrawDuringLiveResize:] + 210
6 libawt.jnilib 0x18017084 -[NSViewAWT getContext:canDrawDuringLiveResize:] + 67
7 libawt.jnilib 0x18016fd0 ViewSD_startCGContext + 239
8 libawt.jnilib 0x18016d69 Java_apple_awt_CRenderer_doRect + 331
9 ??? 0x0800b9d9 0 + 134265305
12 ??? 0x08003e31 0 + 134233649
13 ??? 0x0800430d 0 + 134234893
14 ??? 0x0800430d 0 + 134234893
15 ??? 0x08003e31 0 + 134233649
16 ??? 0x08003e31 0 + 134233649
17 ??? 0x08003e31 0 + 134233649
18 ??? 0x08003e31 0 + 134233649
19 ??? 0x08003e31 0 + 134233649
20 ??? 0x08003e31 0 + 134233649
21 ??? 0x08003e31 0 + 134233649
22 ??? 0x08003e31 0 + 134233649
23 ??? 0x08003e31 0 + 134233649
24 ??? 0x08003e31 0 + 134233649
25 ??? 0x08003e31 0 + 134233649
26 ??? 0x0800430d 0 + 134234893
27 ??? 0x0800430d 0 + 134234893
28 ??? 0x08003e31 0 + 134233649
29 ??? 0x08003e31 0 + 134233649
30 ??? 0x08003f97 0 + 134234007
31 ??? 0x08001374 0 + 134222708
32 libjvm.dylib 0x067220d3 0x6674000 + 712915
33 libjvm.dylib 0x06721e45 0x6674000 + 712261
34 libjvm.dylib 0x06721e17 0x6674000 + 712215
35 libjvm.dylib 0x0672d81f JVM_DoPrivileged + 653
36 libjvmlinkage.dylib 0x02503633 JVM_DoPrivileged + 99
37 libjava.jnilib 0x0254b1df Java_java_security_AccessController_doPrivileged__Ljava_security_PrivilegedAction_2Ljava_security_AccessControlContext_2 + 46
38 ??? 0x0800b9d9 0 + 134265305
39 ??? 0x08003f97 0 + 134234007
40 ??? 0x08004473 0 + 134235251
41 ??? 0x08003e31 0 + 134233649
42 ??? 0x0800405d 0 + 134234205
43 ??? 0x08003e31 0 + 134233649
44 ??? 0x08003e31 0 + 134233649
45 ??? 0x08003e31 0 + 134233649
46 ??? 0x08003e31 0 + 134233649
47 ??? 0x08001374 0 + 134222708
48 libjvm.dylib 0x067220d3 0x6674000 + 712915
49 libjvm.dylib 0x06721e45 0x6674000 + 712261
50 libjvm.dylib 0x0672e80d 0x6674000 + 763917
51 libjvm.dylib 0x0672e69d 0x6674000 + 763549
52 libjvm.dylib 0x0672e61b 0x6674000 + 763419
53 libjvm.dylib 0x0672e475 0x6674000 + 762997
54 libjvm.dylib 0x0672e2b3 0x6674000 + 762547
55 libjvm.dylib 0x066884bc 0x6674000 + 83132
56 libsystem_pthread.dylib 0x92112ecf _pthread_body + 138
57 libsystem_pthread.dylib 0x92112e45 _pthread_start + 162
58 libsystem_pthread.dylib 0x92110f0e thread_start + 34
Thread 36:
8 com.apple.HIToolbox 0x911bc798 ReceiveNextEvent + 90
9 libmt.so 0x1e090f80 Tr::BMsgQueueThread::Execute() + 230
10 libmt.so 0x1e0a2887 Tr::BThread::run(void*) + 39
Thread 37:
0 libsystem_kernel.dylib 0x9446f516 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x92113b7a _pthread_cond_wait + 842
2 libsystem_pthread.dylib 0x92113d9d pthread_cond_timedwait_relative_np + 47
3 libmt.so 0x1e0a638a Tr::BEvent::WaitMs(int) + 118
4 libmt.so 0x1e056739 Tr::TRuntimeDispatcherImpl::Execute() + 145
5 libmt.so 0x1e0567c4 non-virtual thunk to Tr::TRuntimeDispatcherImpl::Execute() + 20
6 libmt.so 0x1e0a2887 Tr::BThread::run(void*) + 39
Thread 38:
2 com.apple.audio.midi.CoreMIDI 0x1e4f6ac3 XServerMachPort::ReceiveMessage(int&, void*, int&) + 123
3 com.apple.audio.midi.CoreMIDI 0x1e513539 MIDIProcess::RunMIDIInThread() + 151
4 com.apple.audio.midi.CoreMIDI 0x1e517914 MIDIProcess::MIDIInPortThread::Run() + 24
5 com.apple.audio.midi.CoreMIDI 0x1e4f7e2b XThread::RunHelper(void*) + 17
6 com.apple.audio.midi.CoreMIDI 0x1e4f796c CAPThread::Entry(CAPThread*) + 134
Thread 35 crashed with X86 Thread State (32-bit):
eax: 0x8fedd52c ebx: 0x98c993cd ecx: 0x00000000 edx: 0x8ff054c0
edi: 0x8ff054c0 esi: 0x8feabf70 ebp: 0xb24d3da8 esp: 0xb24d3d8c
ss: 0x00000023 efl: 0x00000246 eip: 0x8fea9085 cs: 0x0000001b
ds: 0x00000023 es: 0x00000023 fs: 0x00000023 gs: 0x0000000f
cr2: 0x1e9af000
Logical CPU: 0
Error Code: 0x00000000
Trap Number: 3
