pianomangigs
2015-01-28 06:23:19
Hi
I need help building a or a series of translators to do the following...
I am using a midi controller to launch clips and do stuff in ableton.
I want to make translators that will ONLY pass midi (channel 5) note on/off data from my controller to ableton
IF a button ( i.e. note) is pressed 3 times quickly within a second
This will ensure that if I accidently bump or press a button when I am playing it will not mess up the show.
I sure hope this can be done
If possible I would like it simple but if I have too I could make translators for each button which is 48 buttons to debounce
Thank you so much
Jeff
Thank you so much
Jeff
