Filter out second double midi note?
stoecklem
2015-03-30 21:46:41
Hello
If I could get some guidance with this, it would be much appreciated. I'm building a touchscreen control surface with Emulator Pro, which is great until I found it was sending double midi notes. I just can't figure out why and I haven't heard a response back from them yet.
So In the mean time, I'd like to use MT as a solution to filter out the second midi note, so if a second note occurs within under a second, then it is filtered out.
DvlsAdvct
2015-03-30 22:03:12
Yeah, this is doable. It's tough just due to how many buttons you'd be pressing at a single time. Is there always a double message, every single time? If so then it's really easy. If not it becomes a little bit more complicated, but is still doable.
If you need to filter individual messages, we need to know how many buttons you'd expect to press at a single time to allow times to reflect that. If we put a global timer on, it would prevent you from pressing more than one command every second. Does that make sense?
J
stoecklem
2015-03-30 22:28:06
It's very strange. Sometimes its sending out double notes all the time, and then other times only around 80% of the time so unfortunately not all the time. Its a video controller for a Tricaster, so while it would be nice to trigger a few things at once, its really not necessary. A global timer just preventing more than one command should do the trick.
DvlsAdvct
2015-03-31 18:16:10
Then let's set it to less than 1 second, maybe a quarter of a second. If they are happening quickly we can trim it down even more. It should read something like:
Translator 1: Passthrough
Incoming Message: pp qq rr
Rules: if g0==1 then exit rules, skip outgoing action
Outgoing Message: pp qq rr
Translator 2: Lockout Timer
g0=1
Outgoing Message: Lock Out Timer, 250ms delay
Translator 3: Timer
Incoming Message: Lock Out Timer
Rules: g0=0
Outgoing Message: none
So when any message comes in from your controller, it will set a global variable which prevents any other message from triggering. When the timer goes off, after a quarter of a second, it resets the global variable so messages can be sent again. Feel free to play with the delay of the timer to dial in exactly how long you need.
Jared
