DropDP
2015-05-11 14:43:44
I've just downloaded this program looking to use it to turn my Traktor f1 into a keyboard command pad. The only problem I have is that MT does not see the F1 in the "Midi In" list. I would really appreciate some help getting this to work!
So far I have tried:
Restarting the program
Restarting the computer
Using a different controller (Traktor X1 - still doesn't see it)
Disabling my firewall (I use ESET security)
It is interesting to note that I tried MT on my windows 8 laptop and it worked completely fine.
The computer it is having trouble on is a 64bit Windows 7. I'm not sure what other information I need to give that would assist anyone in solving my problem, sorry! If there is any other info you need, let me know.
Thanks in advance for anyone who helps.
