FCB1010 filter out CC on a specific channel
soundtextures
2015-06-07 12:41:46
Dear forum,
dear Florian,
the Behringer FCB1010 is sending out a CC Channel as a tap tempo message every other time you step on it, which can not be deactivated unless you switch to DirectSwitch which renders the board almost useless, or use the UNO Chip.
I´ve set up the CC Channel to 13, which I intend not to use anymore in Ableton Live. So I would like to filter out all CC Messages or - if needed - all messages on Channel 13.
My idea was: Create a rule with Incoming Action BC rr qq (so that any CC on channel 13 will be recognized), swallowing MIDI messages ticked and as an Outgoing Action NONE.
The log shows it´s working, BUT Abelton Live still see´s it!
Tom
Windows 7, Ableton Live 9.1, MT 1.72, M-Audio Firewire 1814
DvlsAdvct
2015-06-08 04:07:31
Hi Tom
Just to be sure, do you still have the FCB1010 connected directly to Ableton, or are you only running it through MT Pro?
Jared
