Mprod
2015-06-15 23:23:17
Hi there,
I need some help here. Is this possible?
I would like to turn my BCR2000 knob with led indicator ring into a 3 or 4 way switch. The message out to the vst is no problem. Im looking for a way to have the knob leds indicate 3 discrete values (or 4 or 5 for that matter). I have been able to turn it in a three way indicator with this
in B0 5A pp.
qq=pp-127
qq=qq+64
out B0 5A qq
I send this message back to the BCR2000 to control the led ring and I make a separate translator to translate the turns to the midi message to a virtual output for the vst.
And this works kinda, but it is extremely sensitive and continuous (setting the bcd to relative makes it absolute, but still very sensitive). I would prefer it to skip to the next led after 1/3 of a turn.
I also looked into the possibility to change the value range of the knob on the BCR2000 itself. I can set it to e.g.from 0 to 2 (so it sends 0,1,2). This kinda works because now you have the first three lights lighting up with each value at nice intervals, but i would prefer the lights to be further apart and have the knob turn a little further (1/3 of the led ring) before it jumps leds.
You can also set the bcr2000 to relative values (and 14 bit for that matter) don't know if this helps.
in B0 5A pp.
qq=pp-127
qq=qq+64
out B0 5A qq
