randallpatrickc
		2015-06-23 23:37:55
	Exciting looking update!
Before I jump, will my existing translator files work ok in 1.8 please?
		wilcofan
		2015-06-24 16:07:22
	If you used WM_messages as outgoing actions, then no.  It appears to have been removed.
1.8 broke my files last night.
		2015-06-24 16:24:20
	wilcofan, sorry for this! I forgot where you've used WM_ messages?
For mouse and keyboard, you can inject those messages, now, which will probably replace using WM_ messages.
Other than that, 1.8 is 100% compatible with 1.7.2.
		wilcofan
		2015-06-24 16:33:25
	I was initially hopeful the "inject" would replace the WM_messages.  After a look, I'm not so sure.
Where I used them was to communicate with AutoHotkey, to perform more detailed commands.  I started using  the WM_messages to trigger functions and scripts.
Yes, I could use keystrokes to trigger these functions, in theory injecting the keystroke to the AutoHotkey script window.  However, this makes for messy work as I am creating hotkeys for functions that I don't intend to actually ever press.  And could by accident.
WM_messages are excellent for this kind of scripting talk.
		2015-06-24 16:45:32
	hmmmm, I don't think that injected keystrokes could ever accidentally cause those keystrokes to be really executed. Internally, injecting keystrokes uses SendMessage just like the WM_ action does, so if AutoHotKey is not running or another window is open, the injected keystrokes will not do anything.
But I get your point.
		wilcofan
		2015-06-24 16:50:48
	No, Bomes won't accidentally cause the keystrokes, *I* might.
Now I have a live trigger in the system that was closed only to Bomes before.
