arvol
2015-07-07 01:55:34
Hey Guys!
I've read through some posts, but still haven't really found what i'm having trouble with.
Had a quick question for you about rules. *I’m using version 1.8*
I have 40 button on my APC40 mkII I am wanting to turn on at the launch of Bomes. (Got this working)
Now I’m wanting to separate these buttons into groups/layers. (8 layers of 5 buttons) (Got this working)
I then want to turn a button from a solid light to a blinking light when pressed. (Got this working)
I then want to have that same button turn BACK to a solid color when a different button (only in that layer) is pressed, AS WELL as having that new button start to flash when pressed. (Can’t figure this out)
And so on, and so on for each layer… wanting all the buttons (per layer) to remain solid unless they are cued up. (one flashing light per layer, as that will be the active clip for that layer)
I’ve spent about 8 hours and all sorts of different ways to output/rule/ and other ways to make this work. I feel that since I have 2 translations with the same incoming midi info, it’s only letting me use one? even when i set variables, or tell the translation to stop processing before moving on to the next one.
I’m sure it’s something simple I’m overlooking.
If anyone has a free min, could someone walk me through what I need to do, step-by-step? I would really appreciate it!
If it matter? This will be used with resolume. I got the mapping down, just need the LED Feedback to work lol
~Arvol
~Arvol
