2015-07-09 09:03:27
Here's a way to use a single LPD8 simultaneously in Live and SSL, using MIDi Translator Pro:
- In both Live and SSL, disable LPD8 as MIDI Input (also close the applications to make sure they're not blocking the MIDI port)
- after installation, open the settings screen
- for virtual MIDI ports select 2 (or more)
- close the settings screen.
- In the Project Properties, scroll down to the MIDI Router
- draw these MIDI routes:
- LPD8->Bome Virtual 1
- LPD8->Bome Virtual 2
- Bome Virtual 1->LPD8
- Bome Virtual 2->LPD8
- Like that, all MIDI data from LPD8 is duplicated to the Virtual 1 and to Virtual 2 ports
- Conversely, data from Virtual 1 and Virtual 2 is merged to go to LPD8
- Open Live, use Virtual 1 Input and Output instead of the LPD8
- Open SSL, use Virtual 2 Input as Output instead of the LPD8
