jimjam
2015-07-24 06:09:54
Hello,
I had a brief look through the forum to make sure I wasn't asking a repeated question; so please kindly re-direct me to a previous thread if this has already been beaten to death.
Here's my question:
I'm setting up a performance rig to run three different programs and I want to use the translator to toggle between them in fullscreen.
I am attempting to do this using some unassigned keys on a APC40.
I did this successfully by using the the midi translator and assigning different notes to "windows key" + 1, 2, 3, 4, etc for each program. (the programs I want opened are in order in the windows taskbar, the "windows key" + # opens the corresponding program in fullscreen and also brings it to the front, which is the desired effect).
My problem is is that it seems that the midi translator has to be visible on the screen in order to use the command i.e. if I press the midi note it brings up the corresponding program in fullscreen (yes!) but if I then hit a note to bring up a different program the midi translator does not respond (no!).
The whole point is that I want to be able to toggle back and forth between programs and I want the translator to run in the background.
I tried unclicking the "stop processing with this translator" box, and it did not change anything.
My hypothesis is that the midi translator only works when it is the active window on screen - but I want to confirm I"m not missing something before moving on to a new solution.
Any ideas?
jimjam
Here's my question:
Any ideas?
jimjam
