Neil Hester
2015-08-14 15:44:06
This has been a long term wish of mine to continue using my Digidesign Pro Control and Fader pack with Pro Tools beyond Pro Tools 10.
For those who do not know this is an ethernet connected control surface the sends a form of midi over ethernet but its not quite so literal as that.
Avid (Owners of Digidesign who have since retired the name) dropped support for the product with Pro Tools at PT10 and refuse to develop the required driver to continue using the unit any further.
So this brings me to the development of an alternative way of using this unit, I love the hardware and will not stop using it so another way must be found.
My investigations have lead me to one person "Indys" who had successfully developed a bridge between the hardware (actually a Control 24 rather than Pro Control but works on the same protocol) the full thread is here on the Reaper user forum:
forum.cockos /showthread.php?t=38389&highlight=control+24
Sadly he was put off by potential legal trouble from Avid (although this is questionable as to whether it even has any substance) and did not release it as a publicly available product.
Legal questions aside (I'm not interested in discussing this) I would like to try and do the same thing for personal use if nothing else.
Sadly I have zero programming knowledge and only have the info in the thread to go by, It appears the data was captured from the hardware using winpcap.org which is readily available but i dont know how to read the data or translate it and I'm wondering if Bome Midi Translator would make the task easier?
Can BMT read the data coming in over the network port and translate to MIDI and vice versa to feed back to the hardware (fader movement and LED Status etc)?
If BMT cannot do it does anyone know enough about what has been discussed in the thread to suggest how i go about learning the language of the data (what even the language is) do do it in the same way as the guy "Indys" appeared to do it ?
I'm willing to learn if anyone can help point me in the right direction, there literally hundreds of people out there in the same situation that just want to be able to use their units but Avid are a brickwall for communication about it.
I've tried to contact "Indys" but not heard back from him yet so in the meantime maybe some of you can help?
Neil
Neil
