mingle51
2015-09-02 17:23:10
I've been working with Bome Midi for about 2 weeks now and love the product.. Seem to be a bit of a learning curve if you plan on scripting any with it.. I have a current project that I am working on to integrate my Ableton Live and my Songshow plus presentation software so Ableton can call up slides.. "That's a chord chart and slide for the audience and different one for the band chord chart". It seems to be working well as songshow has keyboard shortcut that work well with bome midi. I am running the whole thing on a windows 8 and windows 10 OS with intel based i7 processors. It's fast and flawless. The mouse function with Bome midi allows me to use the mouse to fire off presentation slides and the keyboard shortcut with SS Plus lets me do the rest.. Once I finish the project I will post it on youtube maybe a link back to the form for anyone that would like to use the same setup.. Basically it lets my church run live worship sets via multipacks with a live band and jump around and arrange on the fly while pulling slides and chord charts on the fly for the audience and stage/band with chord charts on a large project located at the back of the room.. By using a softstep 2 its hand free also once you have your set..This is all working via midi over wifi. slick..
I need help with the scripting part to advance a chorus.. Something with songshow when using a keyboard shortcut on a chorus is a combination of 2 keys storks to make it advance to the next selected chorus..Basical to go to chorus 2 you need a combination of keystrokes you need to hold "O" key for a sec or 2 and continue to keep it pressed then press and hold the number "2" key for about a 1 sec and release both and the slide will move to chorus 2.. Thinking I might could use some type of timer but not sure how the timers works in bome midi. Can someone point me in the right direction here? I am stuck for the moment which I feel confidant it can be done in bome midi but I just don't know how. Help please???
