le gars aux 3 j
2015-09-14 12:50:35
Hello,
Sorry i don't have a very good english, i will try to do my best to be clear !
I'm a new user and i find BMT is a very clever program. But i have a strange problem whith it...
I use Bome Midi Translator to control a presentation in LibreOffice Impress (it's a powerpoint like), i' work with Windows 7. I send MIDI PC to go to the next slide (NUM ENTER) or to jump tou the slide #12 (NUM 1 NUM 2 NUM ENTER) for exemple.
I program a lot of translators (it's for a show and it's a little complex) and it works fine, i can control the slides in real time.
So i save the program and i close all.
When i open it again, it doesn't work anymore. The MIDI PC are received and tranmitted correctly (i see it in the log window), but it has no effect in L.O. Impress...
If i change the outgoing whith exactly the same thing (NUM ENTER, for example), then it works again !
So i have to do all the programmation each time !
Have you a solution ?
thx
thx
