djjoel
2015-09-15 19:27:14
Hi there.
Let me first begin by stating that I am a complete MIDI newbie.
Here's my problem - I'm unable to use the sustain (damper) pedal on my Roland RD-300s in Ableton Live 9 Suite. The pedal is indeed sending MIDI messages. From the research I've done, I hear it's because these old Roland digital pianos send an "all notes off" function when the key is released, even if the sustain pedal is being pressed.
The user who posted this on the Ableton site was using MidiPipe, but I assume that with Bome we can obviously do the same thing. I don't know if he's using the same model of Roland digital piano, but here is what he wrote:
Thanks and I hope to hear from someone who knows what they're doing soon
I'm hoping to be guided in the right direction as to what I should do. I've never used a MIDI Translator before and it's my second try at this. When I first installed, I declared "screw it", and uninstalled but now I'm determined to get this going and learn some valuable information on thew way!"Through the use of MidiPipe I was able to filter out the 'all notes off' message (CC123) so that Ableton no longer received them and everything worked!
Since it took me a while to figure out how to get MidiPipe to do what I wanted, I thought I'd mention what I did to get it working in the end. I added a 'Midi In' pipe to receive the messages that were coming in from the piano ("hijack" option checked), added a 'Message Converter' pipe and mapped Control Change #123 to Control Change #002 (for example), and lastly a 'Midi Out' pipe to MidiPipe Output 1 ("pass through" option checked)."
