Is it possible to have 2 controllers doing the same function
DJxNightmare
2015-10-09 21:01:10
I have 2 separate controllers (different types) that I want the faders to do the same thing. How do I set that up
Please help!!!
DJxNightmare
2015-10-09 21:25:32
I realize that my post was a little vague. I use Bome to control my laser control software
I use a fader on the APC40 to control color as well as the X and Y axis
I use the numark orbit for a smaller wireless control (for brief control when not at my main control)
I would love to be able to have the apc and the numark have the same output in the bome output for the same function. So I can control color while I am away from my station
DvlsAdvct
2015-10-12 23:11:06
Hi DJxNightmare
Yeah, what you want to do is definitely possible. I would create two different presets, though, to keep your messages separate between the Orbit and the APC. Set the default incoming port for the preset accordingly, and map them however you want. :)
Should definitely be able to map both
Jared
