cashperkins
2015-11-08 23:55:08
Hi..
First post here... so go easy. I've followed the instructions found on allen-heath.com to get this set up with protools. In the bome translator event monitor I see only the MIDI In flash green at a regular pulse cadence... the midi jack flashes green at same cadence as the out led... and the in led flashes red at exactly the same cadence. On my MIDI interface (Digidesign MIDI IO) I see only the green led on the midi in port. Nothing on the corresponding midi out. Out of port 10 on the interface goes to in on the board... out on the board goes to in on the interface. I've tried swapping cables and reversing them does not change things.. which I assume eliminates the possibility that it is a bad cable.
Any thoughts on where I might be going wrong? All help is most appreciated!!!
I would love to get someone willing to help me get my console working properly as a control surface.
Thanks in advance.
-= Cash
Thanks in advance.
-= Cash
