GuitarBass
2015-11-17 18:49:38
Hi, I used Bome midi translator for years in a setup which added bass to my acoustic guitar sound. Thanks for imagining this great product. Now I started to use a new setup: a Fishman TriplePlay guitar to midi converter with a Trilian Bass module and a KMI softstep2 and this sounds and works amazingly well. The 3 lower strings of my guitar trigger the Trilian and by using a sostenuto CC message thru the softstep I can single out those notes to whom I want the Bass sound applied. The Fishman hold function allows to block other incoming midi notes untill I trigger the next sostenuto message. The only trouble I have is when I make full chords in a downward stroke. When I do this my triggering is not fast enough to avoid the other bass notes to sound. When all of the 3 bass strings are triggered, it makes a mess and the last (highest) bass note ends up sounding instead of the lowest one, which is what I would need. Note that I already limited the Trilian to one voice only (so Mono instead of Poly) I wonder if Bome can help somehow to block certain midi note messages to be send out, if they are within a certain limit of time ( say max. 100 milliseconds for example) from a first note message that is send out. If so, can you set me on the way. If you see another way to achieve this, please let me know. I basically need the first note (Low E string on the guitar) which I hit to be send out without having the other two guitar strings A and D to trigger bass. Many thanks for your input. Hein
Florian's answer:
Hi Hein,
thank you for your email and my apologies for the very late reply.
Anyway, regarding your setup: this is definitely possible, in different ways.
One straight forward way is this:
1) when a (first) note comes in:
a) let it through
b) remember this first note in a global variable "g0"
c) start a timer "block simultaneous notes" with 100ms
2) now if another note comes in:
a) check g0. If g0 is not 0 and the new note is higher than g0, swallow it.
b) otherwise pass through the note
3) when the timer "block simultaneous notes" expires, reset g0 to 0
Attached is the preset. Note that the order of translators is important!
Hi Florian,
amazing, just amazing!
Would it (with a slightly adapted preset) also be possible to let pass the lowest string and block the second string?
If so, can you give the preset for the third possibility too: let the two lowest stings pass and block the highest string?
Hein
Hi Hein,
yes, you can arbitrarily block strings -- either by note (range), or by order.
Hope that helps,
Florian.
Florian's answer:
Hi Hein,
a) let it through
Hi Florian,
Hein
Hi Hein,
Hope that helps,
Florian.
- Attachments
- BlockSimultaneousNotes.bmtp
- (2 KiB) Downloaded 182 times
