Multiple Monitor Setup problems
jmd87
2016-01-06 13:27:54
I am using the demo version of Bome Midi Translator and am having a few issues I can't seem to figure out (I have looked in the manual)
I Have a triple monitor setup and basically I use the "Capture" on the mouse coordinates on Monitor 2 which then displays a - coordinate in the box but if I then hit the designated midi key to move the mouse it only moves it to the edge of Monitor 1, It doesn't move on to monitor 2 at all.
Is it something I'm doing wrong?
Kind Regards
Joe
jmd87
2016-01-07 12:40:06
Hi again,
I have also tried this with just a dual Monitor setup and its the same aswell if that helps?
Kind Regards
Joe
2016-01-11 11:27:33
Hi Joe,
indeed, the mouse emulation might not always work on secondary monitors (depending on your monitor setup). We'll look into this to be fixed in (hopefully) the next version.
