chicago64
2016-01-28 19:14:45
Any help for setting up this scenario. I have a Kontakt file I use to play 16 songs. Each song is assigned to midi channel 1-16 and I usually use the keyboard to change the outgoing midi channel to decide which of the 16 songs kontakt will play.
I would like to use another method to change the midi channel Kontakt is receiving instead of the keyboard method. Using a separate midi controller to tap 1 of 16 buttons to change the midi channel Kontakt is receiving. I thought Bome MT could do the trick, but I am looking for suggestions on how best to set this up.
The reason I don't want to use the keyboard for this purpose is because we are a traveling band and each keyboard is different. Sometimes it takes quite a bit of time to figure out on some boards the exact method for changing the outgoing midi channel.
Thanks for any help.
