NiDBiLD
2016-01-29 19:14:59
Hey! I'm thinking of buying Bome MIDI translator, because I'm looking for a solution to a very specific problem. If this can be solved somehow, I'm all in.
Some backstory: I'm building a custom template for my NI Maschine Studio hardware, so that I can use it for controlling Presonus Studio One.
I've successfully managed to get the two of them playing nicely with each other using Mackie MCU protocol. However, since MCU uses midi note data for relaying messages, I can no longer use the pads for note input.
For example, when I change the volume of track 1, C0 (if I remember correctly) lights up, as they are basically the same command.
So, I think what I want to do is to somehow "detach" the pad section of the controller on a software level, and use it as a separate device inside Studio One. So that there, inside S1, is the "Maschine Studio" under MCU control (plus some midi cc's mapped to DAW commands), as well as a very basic keyboard template, which takes care of only the pads.
My wild guess is that the requirement would be that the routing application can somehow make sense of the "source" of the signal, and sort the messages accordingly. Like, if the message is from a knob, do this. If it's from a pad, do that. Can your MIDI translator do this? Would it work? If not, is there a better way?
I hope my question makes sense. Any kind of solution to this problem is extremely welcome - doesn't have to be exactly what I'm asking for if there's a better way to do it.
