Work setup
rifter
2016-02-06 19:34:32
Hi guys, I'm trying to figure out a nice setup to be working in Bome MT with all the info and tools that I need on the screen.
So basically when I want to work I keep open a bunch of links wich are:
http://ascii.cl/conversion.htm
http://en.wikiaudio.org/MIDI:Control_ch ... ssage_list
Bome's Midi Translator Manual: Rules
Metastatik pinned tutorials on this forum (especially Golden Rules)
I'm not a programmer and I'm still filling the first gaps with my MIDI knowladge and I think that finding a good workflow is important for not loosing track.. So I ask if you have some specific tool or well made info charts for helper as you're working with BMT.
DvlsAdvct
2016-02-08 20:07:35
I use this link for Hex and decimal conversions and this link for midi note to hex conversion. I know 1.8 has the drop-down menus but I'm so used to using the raw MIDI code that these just save me a TON of time.
rifter
2016-03-22 12:03:43
Thank you! That's very helpful. To be organized is the first thing, otherwise I never get to the point of really starting anything.
DvlsAdvct
2016-03-22 17:00:22
Exactly.
Let us know if you have any more questions :)
J
