DarrylB
2016-02-20 13:56:21
Hi everyone.
I'm a total newbie to Bome MT. I've downloaded the trial to see if it can do what I need it to and my first impression is that it can but I need some help.
The Numark V7 has a motorized platter with a piece of vinyl on top. The position of the platter is spat out very frequently in the form of a CC value and also as a pitch bend value that I cannot make head nor tail of.
The OtsAV DJ software can handle a velocity value for scratching and pitch/tempo bending and I need to convert from this absolute time based incremental value to an indication of how fast the platter is rotating (velocity value - as sent by e.g. Denon HC4500 controller that Ots Labs already supports).
here is an example of the Bomes log with Deck A spinning at 33 1/3 RPM (AFAIK - it can do both 33 and 45 RPM).
First question - is the timestamp in Bomes MT in milliseconds?
332626 - MIDI IN [Numark V7 MIDI]: B0 00 08
332626 - IN 1.0 Control Change on channel 1 with CC#:0 (0x00) set 'pp' to value=8 (0x08)
332626 - IN 1.1 Control Change on channel 1 with CC#:0 (0x00) set 'pp' to value=8 (0x08)
332626 - MIDI IN [Numark V7 MIDI]: E0 00 7F
332626 - IN 0.0 Pitch Bend on channel 1 with any bend=8064 (0x1F80)
332628 - MIDI IN [Numark V7 MIDI]: B0 00 0B
332628 - IN 1.0 Control Change on channel 1 with CC#:0 (0x00) set 'pp' to value=11 (0x0B)
332628 - IN 1.1 Control Change on channel 1 with CC#:0 (0x00) set 'pp' to value=11 (0x0B)
332628 - MIDI IN [Numark V7 MIDI]: E0 3F 17
332628 - IN 0.0 Pitch Bend on channel 1 with any bend=-5185 (0xFFFFEBBF)
332628 - MIDI IN [Numark V7 MIDI]: B0 00 0E
332629 - IN 1.0 Control Change on channel 1 with CC#:0 (0x00) set 'pp' to value=14 (0x0E)
332629 - IN 1.1 Control Change on channel 1 with CC#:0 (0x00) set 'pp' to value=14 (0x0E)
332629 - MIDI IN [Numark V7 MIDI]: E0 7E 2F
