[SOLVED] BOME MIDI TRANSLATOR DOES NOT WORK WHEN MINIMIZED
ariajazz
2016-03-11 23:56:55
No incoming or outgoing messages when the program is minimized. If you open its interface then will work. Weird, is there any way to set like "always on top" function?
DvlsAdvct
2016-03-12 20:20:26
Hi ariajazz
It should definitely work when minimized. Can you try uninstalling and reinstalling for me?
2016-05-03 22:41:06
Hi ariajazz,
is this still happening? Which OS are you on?
ariajazz
2016-05-04 00:23:05
Problem solved... Reinstalled the software and everything is fine now
