Mackie Control C4
Aldotron
2016-05-15 09:44:19
Im trying to use a Mackie control C4 with windows Cubase. I'm trying to translate the data from the C4 to allow me to use the unit. Changes made in Commander software seem to make no difference. I'm stumped! can anyone help?
DvlsAdvct
2016-05-16 15:18:56
Hi Aldotron
Do you have a copy of MIDI Translator Pro?
I'm trying to find some resources on using the C4 with Cubase but I'm coming up empty.
Jared
Aldotron
2016-05-18 08:41:16
im using the evaluation version of Bome Midi Translator at the moment but im struggling to get started.
Aldotron
2016-05-18 12:27:38
Just got the C4 going. suddenly realised that you just need a Midi loop utility (loopMIDI). assign it as midi out from knob set-up and input to software synth.
DvlsAdvct
2016-05-18 19:32:00
Hi Aldotron
You can also use MT Pro's virtual MIDI ports for that same process. It will be more efficient as long as they are connected to MT Pro.
Jared
