How does one interface Bome with other programs?
Mageofcats
2016-05-15 22:37:14
Let's say that I wanted to interface my keyboard with another program and, for some reason, it won't let me.
I can use Bome's shortcuts to type in my Windows Start menu, but I can't use it to type in Notepad, for instance. But I can use it in my browser.
Would someone please tell a programming-incompetent young'un how he would go about interfacing (?) it with, say, a game, or Notepad, or just anything that it doesn't seem to automatically mesh with.
Thanks... <3
Mageofcats
2016-05-15 23:34:04
After doing some research, I've solved the Notepad issue. But it doesn't interface with the aforementioned game. I'm running it as an administrator now.
DvlsAdvct
2016-05-16 15:21:16
Hi Mageofcats
Unfortunately, MT Pro is not universally perfect with keystroke emulation in all applications. Running everything as administrator definitely helps. In the outgoing portion of the translator there should be an "injection" option, and you can select an application to try and get MT Pro to force the keystroke to the app. That might help
Jared
