jcotton
2016-05-27 15:41:27
I have a MIDI controller that emits value 1 when turned clockwise, and value 65 when turned anticlockwise.
Logic's Controller Assignments window converts this into continuous 0-127 values using the 'Sign Magnitude' format setting. No problem.
However I want to use the same controller with another app (RME totalmix) which doesn't have a 'Sign Magnitude' option - and expects to see absolute values incoming. Currently the faders I'm controlling just flip between value 1 and value 65 (predictably enough!).
Is there a way to use MT to convert incoming Sign Magnitude into absolute values 0-127? Any ideas appreciated.
Thanks - Jon
Thanks - Jon
