Scr1pter
2016-05-30 10:56:10
Hello,
I have the trial version of the BOM MIDI Translator.
(Downloaded it yesterday.)
Actually, I'm really impressed of its functions even though I haven't tested much.
I faced one little issue (I found a little work-around, but maybe there is a cleaner solution).
When you have a list of presets it doesn't seem possible to easily activate/deactivate a preset.
Yes, I know there is a checkbox which can be checked/unchecked, but a script doesn't know this
So I'm looking for a quick way to:
- select a specific preset
- activate or deactivate it (no toggle!)
My work-around would be:
..1. Beeing in the preset area (can be accessed by CTRL+1)
..2. Pressing the arrow keys to go to the specific preset
.....(e.g. x times arrow up, 3 times arrow down = Preset 4)
..3. Placing the mouse cursor on a neutral position in the preset area
..4. Rightclick
..5. Pressing arrow up 4 times
..6. Pressing space bar
Of course I will not do this manually but using a Logitech Script (I have some devices).
It's possible, but I really would prefer not to move the mouse cursor because this is an error source.
Strangely, pressing the menu key of my keyboard (which is normally between RWIN and RCTRL) does nothing.
In the manual I found no shortcuts to activate/deactivate a preset either.
I would like to have this kind of automation because during work I would just press 1 key to switch a preset.
(This would switch to MIDI Translator, activate/deactivate a preset) and switch back to my DAW - within 1 second.
Edit
1. I use the trial of the MIDI Translator Pro
2. Shift+F10 doesn't work either. So maybe it's not a problem with the menu key itself but a general problem. F10 works to open the title menu, though.
Edit 2
Last question (for this thread):
Is it true that MIDI Translator Pro must always be maximized in order to work?
I saw a YouTube video where a guy said that if you minimized it, it wouldn't work anymore.
It has to be maximized (can be in background, but maximized.)
Best regards
..4. Rightclick
Edit
Edit 2
Best regards
