tsutek
2016-06-19 20:54:25
First of all, let me say I'm really excited about joining the Bome club!
Been reading this board a bit, but getting around to catching up soon.
Just wanted to ask some opinion about my first bome script. First it's probably good to explain my intentions with the script.
I have a MPD218 pad controller that is triggering notes of a drum machine. I want to reserve the first four pads to special functions, while the 12 pads underneath are sending midi notes to trigger the drum sounds / synth notes.
So I have mapped the first 4 pads to transmit midi notes 124, 125, 126, 127 on channel 16
The remaining pads are triggering notes chromatically from notes 000-011 on channel 01
Now the script itself has two translators. First one handles program change increment, and the second one handles program change decrement. Here is the code:
Does it look like I am doing everything correctly? I am asking because it's my first script and I am not 100% sure the script works flawlessly.. Like, is it safe to use a global variable for translating data like this? Should I copy the value of gp to a local, say, "pp" before going out from a translation? Also, what about note offs (velo 0), will they cause the translations to run twice or unpredicatbly?
Cheers
Project: MPD218-AR-CTRL002
_____________________________________________________________
[x] Preset 0: MPD218-AR-CTRL001
[x] Translator 0.0: MPD218-PRGC-INC
Incoming: Takes Note #127 from ch16 of MPD218 and converts to pgm chng (+) - if pgm chng = 127, action is ignored, on port MPD218 Port A
if gp==127 then exit rules, skip Outgoing Action
gp=gp+1
Outgoing: Program Change on channel 1 with program:gp, to port Bome MIDI Translator 1 Virtual Out
[x] Translator 0.1: MPD218-PRGC-DEC
Incoming: Takes Note #126 from ch16 of MPD218 and converts to pgm chng (-) - if pgm chng = 0, action is ignored, on port MPD218 Port A
if gp==0 then exit rules, skip Outgoing Action
gp=gp-1
Cheers
