slashinfty
2016-06-23 18:53:41
I'm attempting to use MIDI Translator to control OBS Studio hotkeys, and in OBS Studio, hotkeys can be used globally only if the program is ran as an administrator.
One of my translators changes a MIDI message to the keystroke Ctrl(Alt(Shirt(Insert )))), and if OBS Studio is the active window, I can press the corresponding button on my MIDI controller to send that MIDI message and it triggers that keystroke and the proper hotkey is applied (in this case, muting or unmuting my microphone). Correction: if I run OBS Studio as an administrator, in the hopes to have global hotkeys, this does not work at all, even if OBS Studio is the active window.
If OBS Studio is ran as an administrator and not the active window, and I press the keystroke combination of Ctrl(Alt(Shirt(Insert )))) on my physical keyboard, the hotkey activates and my microphone is muted/unmuted. However, if I attempt to press the button my MIDI controller to send the appropriate MIDI message and have it translated to the correct keystroke combination, it fails to trigger the hotkey.
Summation:
OBS Studio active + MIDI controller pressed = does not work (originally said it did work, but does not if OBS Studio is opened as an administrator)
OBS Studio active + keyboard combination pressed = works
OBS Studio not active + MIDI controller pressed = does not work (want to work)
OBS Studio not active + keyboard combination pressed = works
I have tried to run MIDI Translator as both an administrator and not, and have not had success. Is there anything more than can be done? Thank you.
Summation:
