iamjon
2016-06-24 23:34:13
I have a Keith McMillen Quneo. It sends CC# data along the XY axis of little square drum pads.
It sends 0-127 values which is way too extreme a variation for something like filter frequency. I want to translate the values to send something more like 40-60. The Y CC is 39 the X CC is 29.
I set up my project with QUNEO as input and BMT virtual out 1 as output. I set up Reason to accept input from BMT virtual out 1. In BMT I set the midi through and I get the Quneo input firing the Reason instruments via BMT.
In the translator I set two separate but mostly identical translators. One for CC 39 and one for CC 29. For my first test I want to just set output to be 127 for each CC. I can't get this to work. I tried both using the output section to set the value and using the rules scripting box to manipulate a variable set in the input box.
I've attached the bmtp file. Can you tell me what I am doing wrong?
thanks! I am hopeful this will work.
- Attachments
- jon.first.bmtp
- (994 Bytes) Downloaded 169 times
