toniostarcevic
2016-07-08 12:15:27
Hello,
thanks for this great software. It fixed an issue I had for years. Changing presets of virtual instruments/effects (VST) with MIDI controls.
The previous/next preset-buttons of a VST are one of the few controls of music software, that can't be assigned to MIDI natively.
So I just use MIDI Translator Pro to assign mouse clicks to it.
I use it also for the transport funtions (stop/play/record) of the music software (DAW), that also can't be assigned to MIDI.
The only downside is, that you have to drag the windows to the same position every time.
The feature "Windows: inject event" unfortunately works with any window that I've tested except VST windows. The only case I need it for.
Is there a way to improve this feature/enhance its compatibility?
Best regards,
Toni
Best regards,
Toni
