Scr1pter
2016-06-20 14:53:23
I plan to work with hold and double tab too.
First I want to try it with hold.
My idea was to test it with keystrokes.
Numlock 0 and Numlock 3.
If Numlock 0 is pressed, Numlock 3 executes an action.
If Numlock 0 is not pressed, Numlock 3 does nothing.
(Later I will use the same logic on my MIDI device.)
I tried this:
The rules of Num3_down_up are:
I expected then when pressing Num3, nothing will happen.
When pressing and holding Num0 and pressing Num3, the mouse cursor will move.
However, the mouse cursor always gets moved, no matter if Num0 is pressed or not.
Can you help me?
I tried this:
Name..................................Incoming Trigger...........Outgoing Action..............Options
[0]Num0_down..........................Key down: Num 0............(none).......................pp=1
[1]Num0_up............................Key up: Num 0..............(none).......................pp=0
[2]Num3_down_up.......................Physical Keys: Num 3.......Mouse move to X=1846 Y=117...5 rules
if pp==1 then
if pp==0 then
exit rules, skip Outgoing Action
Can you help me?
