gabriels
2016-08-16 19:20:50
I've been noticing this over the past few weeks but don't know what to make of it.
Parts of my MT code seem to stop working as they should. When I inspect the code I notice that Incoming Triggers and/or Outgoing Actions have been changed to "Note On channel 1 with note 60 (0x3C) and velocity (0x7F).
At first, I thought I might have done it inadvertently, but it's happened several times now, and I just can't believe I keep on making such a peculiar mistake. The attached jpg shows the first of several initialization translators with this problem. All translators originally had "Physical Keys L" as the input - and similar outputs (the first output was originally a timer for APC1 LEDS, though).
I'm still working on the code, so it's not clear that this would happen during normal usage, but it's troubling.
Any ideas?
Gabriel
Any ideas?
Gabriel
