3dchrisdodds
2016-09-14 16:40:56
Hi all.
I have just picked up Midi Translator in the hope of using it to route midi signals from one APC 40 to 2 separate software apps (Resolume and OSIMidi (For Titan))
I have watched a tutorial that suggests using RTPMidi, which I believe makes a virtual port clone of your Midi interface (Please correct me if I am wrong) This then allows the two separate apps to see the Midi controller without the error message *Port already in use*
I have got it working with the attached project file but I am unsure if there is a cleaner way to do this. I have two Translators bringing the midi in from the interface and each one routes to its respected virtual port via another translator.
I am still trying to get my head around this but I am sure there is a simpler way to go about this.
- Attachments
- Boome NEW.bmtp
- (2.17 KiB) Downloaded 128 times
