gabriels
2016-09-19 04:24:01
I seems I can capture the position of my cursor on my 2nd screen (running a second instance of Ableton Live), but when MT output attempts to move the cursor to that position (using Mouse/Mouse Position) the cursor seems to stick to the left edge of the second screen. It does get the vertical position correctly, but horizontal movement seems as if it hits a brick wall just as the cursor moves onto the second screen.
For example, if I capture the position x (below), the cursor will move to position o.
I think MT is correctly "logging" the cursor position, since the displayed co-ordinates continue to track both x and y mouse movement as it moves to the 2nd screen. However, the cursor is stuck at the left border of the 2nd screen when my program runs and I request movement.
Gabriel
Gabriel
