ibanman555
2016-10-04 00:35:29
ibanman555
2016-10-04 00:35:29
2016-10-04 11:10:15
mike maxwell
2016-10-04 14:22:33
ibanman555
2016-10-04 17:42:35
Ok good to know... I have a very powerful PC (Intel DX97SR, Intel i7-3930k, 64 GB ram, Windows 7 64bit)florian wrote:I don't think that the project file is big enough to cause noticeable lag -- assuming you're not using a slow computer? Are you on Windows or OS X?
These controllers faders are designed to work at 38400 bps, which is slightly faster than the midi protocol (31250 bps). I've got the controllers configured properly in BMT and under their respective properties in the device manager of Windows. So everything matches up. They are directly connected to a StarTech 8 Port RS232 PCI Serial Card with 16950 UART. The drivers are as up to date as available. In regards to send and receive, I really am only sending back to the controllers from the PC (one direction) that is showing latency. I have just recently resolved a "round robin" or "loop" situation that I thought might help the issue, and I see that is no longer an issue, but hasn't improved the speed at all. I've also dumbed down the messages to "running status" where I could to lessen the bit flow. It does certainly seem like a bottleneck situation, and is immediate from the beginning. When I move a group of 8 faders (the max on one port) it can take up to 5 seconds for the translations to complete. I can watch the log run through it all in that time.florian wrote:I see that the RS232 connections are rather slow (2.4, 19, or 38 kbit/s) so it is possible that sending to these ports causes other (MIDI) messages to need to wait for them. That also depends on the operating system and the serial drivers. It might even be (depending on drivers) that you cannot send and receive at the same time from a port, causing some more lag. Is the lag noticeable from the beginning, or does it need some messages before it starts lagging? Is it constant over time, or does it build up, even after minutes?
64909389 - IN 6.51 MIDI 6 bytes B0 00 7D B0 20 20, pp=0x7D qq=0x20
64909395 - IN 6.52 MIDI 6 bytes B0 01 7C B0 21 00, pp=0x7C qq=0x00
64909400 - IN 6.53 MIDI 6 bytes B0 02 7C B0 22 00, pp=0x7C qq=0x00
64909405 - IN 6.54 MIDI 6 bytes B0 03 7C B0 23 00, pp=0x7C qq=0x00
64909410 - IN 6.55 MIDI 6 bytes B0 04 7C B0 24 00, pp=0x7C qq=0x00
64909415 - IN 6.56 MIDI 6 bytes B0 05 7C B0 25 00, pp=0x7C qq=0x00
64909415 - IN 6.57 MIDI 6 bytes B0 06 7C B0 26 00, pp=0x7C qq=0x00
64909417 - IN 6.58 MIDI 6 bytes B0 07 7C B0 27 00, pp=0x7C qq=0x00
64909422 - IN 6.51 MIDI 6 bytes B0 00 7C B0 20 00, pp=0x7C qq=0x00.....omitted a good chunk...
64916458 - IN 6.51 MIDI 6 bytes B0 00 7F B0 20 60, pp=0x7F qq=0x60
64916463 - IN 6.52 MIDI 6 bytes B0 01 7E B0 21 20, pp=0x7E qq=0x20
64916468 - IN 6.53 MIDI 6 bytes B0 02 7E B0 22 20, pp=0x7E qq=0x20
64916478 - IN 6.54 MIDI 6 bytes B0 03 7E B0 23 20, pp=0x7E qq=0x20
64916483 - IN 6.55 MIDI 6 bytes B0 04 7E B0 24 20, pp=0x7E qq=0x20
64916488 - IN 6.56 MIDI 6 bytes B0 05 7E B0 25 20, pp=0x7E qq=0x20
64916493 - IN 6.57 MIDI 6 bytes B0 06 7E B0 26 20, pp=0x7E qq=0x20
64916498 - IN 6.58 MIDI 6 bytes B0 07 7E B0 27 20, pp=0x7E qq=0x20
mike maxwell
2016-10-04 20:11:52
ibanman555
2016-10-04 20:23:02
Practically zero.mike maxwell wrote:out of interest, how much PC CPU is being used when you're pushing the controller faders around?
mike maxwell
2016-10-04 20:30:52
Definitely punting back to Bome then...ibanman555 wrote:Practically zero.mike maxwell wrote:out of interest, how much PC CPU is being used when you're pushing the controller faders around?
2016-10-07 15:36:46
ibanman555
2016-10-09 19:02:12
florian wrote: I assume that sending the data over the serial port somehow causes the delay. MT Pro's MIDI engine is heavily optimized to not block internally.
I am really starting to think there is an overflow of data here since I am sniffing the midi directly from my application, and there is a lot!! I need to figure the easy way to know if that is the case.florian wrote: MIDI-DIN can pass approx. 3 bytes per millisecond, at 38400kbits it's a bit faster, but not much. Maybe you can deduct from your log how many bytes you're sending.
ibanman555
2016-10-10 16:19:04
ibanman555
2016-10-10 19:51:14
1849604 - OUT 6.35 MIDI B0 48 7F
1849619 - OUT 6.37 MIDI B1 48 7F
1849649 - OUT 6.39 MIDI B2 48 7F
1849689 - OUT 6.41 MIDI B3 48 7F
1849749 - OUT 6.43 MIDI B4 48 7F
1849784 - OUT 6.45 MIDI B5 48 7F
1849809 - OUT 6.47 MIDI B6 48 7F
1849814 - OUT 6.49 MIDI B7 48 7F
mike maxwell
2016-10-10 20:19:31
ibanman555
2016-10-10 21:45:33
Then we were talking my serial controllers send 38400 baud rate, that's faster than midi...florian wrote: MIDI-DIN can pass approx. 3 bytes per millisecond
2016-10-10 22:05:52
ibanman555
2016-10-10 22:22:13
10575433 - OUT 6.35 MIDI B0 48 7F
10575433 - IN 6.37 MIDI 6 bytes B0 0C 01 B0 2C 47
10575443 - OUT 6.37 MIDI B1 48 7F
10575443 - IN 6.39 MIDI 6 bytes B0 0C 02 B0 2C 47
10575448 - OUT 6.39 MIDI B2 48 7F
10575448 - IN 6.41 MIDI 6 bytes B0 0C 03 B0 2C 47
10575453 - OUT 6.41 MIDI B3 48 7F
10575453 - IN 6.43 MIDI 6 bytes B0 0C 04 B0 2C 47
10575463 - OUT 6.43 MIDI B4 48 7F
10575463 - IN 6.45 MIDI 6 bytes B0 0C 05 B0 2C 47
10575468 - OUT 6.45 MIDI B5 48 7F
10575468 - IN 6.47 MIDI 6 bytes B0 0C 06 B0 2C 47
10575473 - OUT 6.47 MIDI B6 48 7F
10575473 - IN 6.49 MIDI 6 bytes B0 0C 07 B0 2C 47
10575478 - OUT 6.49 MIDI B7 48 7F
10575931 - IN 6.34 MIDI 6 bytes B0 0C 00 B0 2C 07
10575933 - OUT 6.34 MIDI B0 48 00
10575933 - IN 6.36 MIDI 6 bytes B0 0C 01 B0 2C 07
10575943 - OUT 6.36 MIDI B1 48 00
10575943 - IN 6.38 MIDI 6 bytes B0 0C 02 B0 2C 07
10575953 - OUT 6.38 MIDI B2 48 00
10575953 - IN 6.40 MIDI 6 bytes B0 0C 03 B0 2C 07
10575958 - OUT 6.40 MIDI B3 48 00
10575958 - IN 6.42 MIDI 6 bytes B0 0C 04 B0 2C 07
10575963 - OUT 6.42 MIDI B4 48 00
10575963 - IN 6.44 MIDI 6 bytes B0 0C 05 B0 2C 07
10575978 - OUT 6.44 MIDI B5 48 00
10575978 - IN 6.46 MIDI 6 bytes B0 0C 06 B0 2C 07
10575983 - OUT 6.46 MIDI B6 48 00
10575983 - IN 6.48 MIDI 6 bytes B0 0C 07 B0 2C 07
10575998 - OUT 6.48 MIDI B7 48 00
ibanman555
2016-10-10 22:24:04
11237865 - MIDI OUT [COM10]: B0 48 00
11237866 - MIDI OUT [COM10]: B1 48 00
11237876 - MIDI OUT [COM10]: B2 48 00
11237896 - MIDI OUT [COM10]: B3 48 00
11237906 - MIDI OUT [COM10]: B4 48 00
11237911 - MIDI OUT [COM10]: B5 48 00
11237916 - MIDI OUT [COM10]: B6 48 00
11237931 - MIDI OUT [COM10]: B7 48 00
11238135 - MIDI OUT [COM10]: B0 48 7F
11238136 - MIDI OUT [COM10]: B1 48 7F
11238141 - MIDI OUT [COM10]: B2 48 7F
11238146 - MIDI OUT [COM10]: B3 48 7F
11238156 - MIDI OUT [COM10]: B4 48 7F
11238171 - MIDI OUT [COM10]: B5 48 7F
11238181 - MIDI OUT [COM10]: B6 48 7F
11238186 - MIDI OUT [COM10]: B7 48 7F
ibanman555
2016-10-10 22:54:37
12922082 - MIDI OUT [COM10]: B0 48 00
12922086 - MIDI OUT [COM10]: B1 48 00
12922091 - MIDI OUT [COM10]: B2 48 00
12922096 - MIDI OUT [COM10]: B3 48 00
12922101 - MIDI OUT [COM10]: B4 48 00
12922111 - MIDI OUT [COM10]: B5 48 00
12922121 - MIDI OUT [COM10]: B6 48 00
12922126 - MIDI OUT [COM10]: B7 48 00...44ms
12922352 - MIDI OUT [COM10]: B0 48 7F
12922361 - MIDI OUT [COM10]: B1 48 7F
12922376 - MIDI OUT [COM10]: B2 48 7F
12922421 - MIDI OUT [COM10]: B3 48 7F
12922461 - MIDI OUT [COM10]: B4 48 7F
12922471 - MIDI OUT [COM10]: B5 48 7F
12922476 - MIDI OUT [COM10]: B6 48 7F
12922491 - MIDI OUT [COM10]: B7 48 7F...139ms
ibanman555
2016-10-10 23:02:08
2016-10-10 23:03:09
ibanman555
2016-10-10 23:11:54
14104936 - MIDI OUT [COM10]: B0 48 00
14104938 - MIDI OUT [COM10]: B1 48 00
14104953 - MIDI OUT [COM10]: B2 48 00
14104968 - MIDI OUT [COM10]: B3 48 00
14104978 - MIDI OUT [COM10]: B4 48 00
14104988 - MIDI OUT [COM10]: B5 48 00
14105018 - MIDI OUT [COM10]: B6 48 00
14105073 - MIDI OUT [COM10]: B7 48 00
14105206 - MIDI OUT [COM10]: B0 48 7F
14105208 - MIDI OUT [COM10]: B1 48 7F
14105213 - MIDI OUT [COM10]: B2 48 7F
14105238 - MIDI OUT [COM10]: B3 48 7F
14105273 - MIDI OUT [COM10]: B4 48 7F
14105278 - MIDI OUT [COM10]: B5 48 7F
14105328 - MIDI OUT [COM10]: B6 48 7F
14105333 - MIDI OUT [COM10]: B7 48 7F
14105606 - MIDI OUT [Bome MIDI Translator 1 Virtual Out]: 90 00 7F
14105606 - MIDI OUT [Bome MIDI Translator 2 Virtual Out]: 90 00 7F
14105606 - MIDI OUT [Bome MIDI Translator 3 Virtual Out]: 90 00 7F
14105606 - MIDI OUT [Bome MIDI Translator 4 Virtual Out]: 90 00 7F
14105726 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 0C
14105726 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 06
14105726 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 00
14105726 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 07
14105726 - MIDI OUT [COM10]: B0 48 00
14105726 - MIDI IN [Bome MIDI Translator 2 Virtual In]: B0 0C 0C
14105726 - MIDI IN [Bome MIDI Translator 2 Virtual In]: B0 2C 06
14105726 - MIDI IN [Bome MIDI Translator 3 Virtual In]: B0 0C 0C
14105726 - MIDI IN [Bome MIDI Translator 3 Virtual In]: B0 2C 06
14105726 - MIDI IN [Bome MIDI Translator 4 Virtual In]: B0 0C 0C
14105726 - MIDI IN [Bome MIDI Translator 4 Virtual In]: B0 2C 06
14105763 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 01
14105763 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 07
14105763 - MIDI OUT [COM10]: B1 48 00
14105768 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 02
14105768 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 07
14105768 - MIDI OUT [COM10]: B2 48 00
14105783 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 03
14105783 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 07
14105783 - MIDI OUT [COM10]: B3 48 00
14105818 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 04
14105818 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 07
14105818 - MIDI OUT [COM10]: B4 48 00
14105848 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 05
14105848 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 07
14105848 - MIDI OUT [COM10]: B5 48 00
14105908 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 06
14105908 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 07
14105908 - MIDI OUT [COM10]: B6 48 00
14105918 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 07
14105918 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 07
14105918 - MIDI OUT [COM10]: B7 48 00
14105986 - MIDI IN [Bome MIDI Translator 1 Virtual In]: 90 00 00
14105986 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 0C
14105986 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 46
14105986 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 00
14105986 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 47
14105986 - MIDI OUT [COM10]: B0 48 7F
14105986 - MIDI IN [Bome MIDI Translator 2 Virtual In]: 90 00 00
14105986 - MIDI IN [Bome MIDI Translator 2 Virtual In]: B0 0C 0C
14105986 - MIDI IN [Bome MIDI Translator 2 Virtual In]: B0 2C 46
14105986 - MIDI IN [Bome MIDI Translator 3 Virtual In]: 90 00 00
14105986 - MIDI IN [Bome MIDI Translator 3 Virtual In]: B0 0C 0C
14105986 - MIDI IN [Bome MIDI Translator 3 Virtual In]: B0 2C 46
14105986 - MIDI IN [Bome MIDI Translator 4 Virtual In]: 90 00 00
14105986 - MIDI IN [Bome MIDI Translator 4 Virtual In]: B0 0C 0C
14105986 - MIDI IN [Bome MIDI Translator 4 Virtual In]: B0 2C 46
14105988 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 01
14105988 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 47
14105988 - MIDI OUT [COM10]: B1 48 7F
14105998 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 02
14105998 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 47
14105998 - MIDI OUT [COM10]: B2 48 7F
14106008 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 03
14106008 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 47
14106008 - MIDI OUT [COM10]: B3 48 7F
14106028 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 04
14106028 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 47
14106028 - MIDI OUT [COM10]: B4 48 7F
14106068 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 05
14106068 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 47
14106068 - MIDI OUT [COM10]: B5 48 7F
14106078 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 06
14106078 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 47
14106078 - MIDI OUT [COM10]: B6 48 7F
14106098 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 07
14106098 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 47
14106098 - MIDI OUT [COM10]: B7 48 7F
14106386 - MIDI OUT [Bome MIDI Translator 1 Virtual Out]: 90 00 7F
14106386 - MIDI OUT [Bome MIDI Translator 2 Virtual Out]: 90 00 7F
14106386 - MIDI OUT [Bome MIDI Translator 3 Virtual Out]: 90 00 7F
14106386 - MIDI OUT [Bome MIDI Translator 4 Virtual Out]: 90 00 7F
14106506 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 0C
14106506 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 06
14106506 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 00
14106506 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 07
14106506 - MIDI OUT [COM10]: B0 48 00
14106506 - MIDI IN [Bome MIDI Translator 2 Virtual In]: B0 0C 0C
14106506 - MIDI IN [Bome MIDI Translator 2 Virtual In]: B0 2C 06
14106506 - MIDI IN [Bome MIDI Translator 3 Virtual In]: B0 0C 0C
14106506 - MIDI IN [Bome MIDI Translator 3 Virtual In]: B0 2C 06
14106506 - MIDI IN [Bome MIDI Translator 4 Virtual In]: B0 0C 0C
14106506 - MIDI IN [Bome MIDI Translator 4 Virtual In]: B0 2C 06
14106528 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 01
14106528 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 07
14106528 - MIDI OUT [COM10]: B1 48 00
14106543 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 02
14106543 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 07
14106543 - MIDI OUT [COM10]: B2 48 00
14106558 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 03
14106558 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 07
14106558 - MIDI OUT [COM10]: B3 48 00
14106583 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 04
14106583 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 07
14106583 - MIDI OUT [COM10]: B4 48 00
14106588 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 05
14106588 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 07
14106588 - MIDI OUT [COM10]: B5 48 00
14106593 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 06
14106593 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 07
14106593 - MIDI OUT [COM10]: B6 48 00
14106598 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 07
14106598 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 07
14106598 - MIDI OUT [COM10]: B7 48 00
14106776 - MIDI IN [Bome MIDI Translator 1 Virtual In]: 90 00 00
14106776 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 0C
14106776 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 46
14106776 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 00
14106776 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 47
14106776 - MIDI OUT [COM10]: B0 48 7F
14106776 - MIDI IN [Bome MIDI Translator 2 Virtual In]: 90 00 00
14106776 - MIDI IN [Bome MIDI Translator 2 Virtual In]: B0 0C 0C
14106776 - MIDI IN [Bome MIDI Translator 2 Virtual In]: B0 2C 46
14106776 - MIDI IN [Bome MIDI Translator 3 Virtual In]: 90 00 00
14106776 - MIDI IN [Bome MIDI Translator 3 Virtual In]: B0 0C 0C
14106776 - MIDI IN [Bome MIDI Translator 3 Virtual In]: B0 2C 46
14106776 - MIDI IN [Bome MIDI Translator 4 Virtual In]: 90 00 00
14106776 - MIDI IN [Bome MIDI Translator 4 Virtual In]: B0 0C 0C
14106776 - MIDI IN [Bome MIDI Translator 4 Virtual In]: B0 2C 46
14106778 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 01
14106778 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 47
14106778 - MIDI OUT [COM10]: B1 48 7F
14106783 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 02
14106783 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 47
14106783 - MIDI OUT [COM10]: B2 48 7F
14106788 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 03
14106788 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 47
14106788 - MIDI OUT [COM10]: B3 48 7F
14106793 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 04
14106793 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 47
14106793 - MIDI OUT [COM10]: B4 48 7F
14106798 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 05
14106798 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 47
14106798 - MIDI OUT [COM10]: B5 48 7F
14106843 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 06
14106843 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 47
14106843 - MIDI OUT [COM10]: B6 48 7F
14106888 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 07
14106888 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 47
14106888 - MIDI OUT [COM10]: B7 48 7F
14107176 - MIDI OUT [Bome MIDI Translator 1 Virtual Out]: 90 00 7F
14107176 - MIDI OUT [Bome MIDI Translator 2 Virtual Out]: 90 00 7F
14107176 - MIDI OUT [Bome MIDI Translator 3 Virtual Out]: 90 00 7F
14107176 - MIDI OUT [Bome MIDI Translator 4 Virtual Out]: 90 00 7F
14107286 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 0C
14107286 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 06
14107286 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 00
14107286 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 07
14107286 - MIDI OUT [COM10]: B0 48 00
14107286 - MIDI IN [Bome MIDI Translator 2 Virtual In]: B0 0C 0C
14107286 - MIDI IN [Bome MIDI Translator 2 Virtual In]: B0 2C 06
14107286 - MIDI IN [Bome MIDI Translator 3 Virtual In]: B0 0C 0C
14107286 - MIDI IN [Bome MIDI Translator 3 Virtual In]: B0 2C 06
14107286 - MIDI IN [Bome MIDI Translator 4 Virtual In]: B0 0C 0C
14107286 - MIDI IN [Bome MIDI Translator 4 Virtual In]: B0 2C 06
14107308 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 01
14107308 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 07
14107308 - MIDI OUT [COM10]: B1 48 00
14107323 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 02
14107323 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 07
14107323 - MIDI OUT [COM10]: B2 48 00
14107353 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 03
14107353 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 07
14107353 - MIDI OUT [COM10]: B3 48 00
14107378 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 04
14107378 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 07
14107378 - MIDI OUT [COM10]: B4 48 00
14107428 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 05
14107428 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 07
14107428 - MIDI OUT [COM10]: B5 48 00
14107498 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 06
14107498 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 07
14107498 - MIDI OUT [COM10]: B6 48 00
14107523 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 07
14107523 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 07
14107523 - MIDI OUT [COM10]: B7 48 00
14107556 - MIDI IN [Bome MIDI Translator 1 Virtual In]: 90 00 00
14107556 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 0C
14107556 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 46
14107556 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 00
14107556 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 47
14107556 - MIDI OUT [COM10]: B0 48 7F
14107556 - MIDI IN [Bome MIDI Translator 2 Virtual In]: 90 00 00
14107556 - MIDI IN [Bome MIDI Translator 2 Virtual In]: B0 0C 0C
14107556 - MIDI IN [Bome MIDI Translator 2 Virtual In]: B0 2C 46
14107556 - MIDI IN [Bome MIDI Translator 3 Virtual In]: 90 00 00
14107556 - MIDI IN [Bome MIDI Translator 3 Virtual In]: B0 0C 0C
14107556 - MIDI IN [Bome MIDI Translator 3 Virtual In]: B0 2C 46
14107556 - MIDI IN [Bome MIDI Translator 4 Virtual In]: 90 00 00
14107556 - MIDI IN [Bome MIDI Translator 4 Virtual In]: B0 0C 0C
14107556 - MIDI IN [Bome MIDI Translator 4 Virtual In]: B0 2C 46
14107598 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 01
14107598 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 47
14107598 - MIDI OUT [COM10]: B1 48 7F
14107603 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 02
14107603 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 47
14107603 - MIDI OUT [COM10]: B2 48 7F
14107608 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 03
14107608 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 47
14107608 - MIDI OUT [COM10]: B3 48 7F
14107613 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 04
14107613 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 47
14107613 - MIDI OUT [COM10]: B4 48 7F
14107648 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 05
14107648 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 47
14107648 - MIDI OUT [COM10]: B5 48 7F
14107663 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 06
14107663 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 47
14107663 - MIDI OUT [COM10]: B6 48 7F
14107693 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 07
14107693 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 47
14107693 - MIDI OUT [COM10]: B7 48 7F
14107956 - MIDI OUT [Bome MIDI Translator 1 Virtual Out]: 90 00 7F
14107956 - MIDI OUT [Bome MIDI Translator 2 Virtual Out]: 90 00 7F
14107956 - MIDI OUT [Bome MIDI Translator 3 Virtual Out]: 90 00 7F
14107956 - MIDI OUT [Bome MIDI Translator 4 Virtual Out]: 90 00 7F
14108076 - MIDI OUT [COM10]: B0 48 00
14108078 - MIDI OUT [COM10]: B1 48 00
14108088 - MIDI OUT [COM10]: B2 48 00
14108133 - MIDI OUT [COM10]: B3 48 00
14108158 - MIDI OUT [COM10]: B4 48 00
14108173 - MIDI OUT [COM10]: B5 48 00
14108258 - MIDI OUT [COM10]: B6 48 00
14108278 - MIDI OUT [COM10]: B7 48 00
14108336 - MIDI OUT [COM10]: B0 48 7F
14108338 - MIDI OUT [COM10]: B1 48 7F
Closed COM 10
14123398 - Settings saved successfully to C:\Users\SmallDogPro\AppData\Roaming\Bome\MIDITranslatorPro.bmts.
14131457 - MIDI OUT [Bome MIDI Translator 1 Virtual Out]: 90 00 7F
14131457 - MIDI OUT [Bome MIDI Translator 2 Virtual Out]: 90 00 7F
14131457 - MIDI OUT [Bome MIDI Translator 3 Virtual Out]: 90 00 7F
14131457 - MIDI OUT [Bome MIDI Translator 4 Virtual Out]: 90 00 7F
14131577 - MIDI OUT [COM10]: B0 48 00
14131577 - MIDI OUT [COM10]: B1 48 00
14131577 - MIDI OUT [COM10]: B2 48 00
14131577 - MIDI OUT [COM10]: B3 48 00
14131577 - MIDI OUT [COM10]: B4 48 00
14131577 - MIDI OUT [COM10]: B5 48 00
14131577 - MIDI OUT [COM10]: B6 48 00
14131577 - MIDI OUT [COM10]: B7 48 00
14131837 - MIDI IN [Bome MIDI Translator 1 Virtual In]: 90 00 00
14131837 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 0C
14131837 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 46
14131837 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 00
14131837 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 47
14131837 - MIDI OUT [COM10]: B0 48 7F
14131837 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 01
14131837 - MIDI OUT [COM10]: B1 48 7F
14131837 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 02
14131837 - MIDI OUT [COM10]: B2 48 7F
14131837 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 03
14131837 - MIDI OUT [COM10]: B3 48 7F
14131837 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 04
14131837 - MIDI OUT [COM10]: B4 48 7F
14131837 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 05
14131837 - MIDI OUT [COM10]: B5 48 7F
14131837 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 06
14131837 - MIDI OUT [COM10]: B6 48 7F
14131837 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 07
14131837 - MIDI OUT [COM10]: B7 48 7F
14131837 - MIDI IN [Bome MIDI Translator 2 Virtual In]: 90 00 00
14131837 - MIDI IN [Bome MIDI Translator 2 Virtual In]: B0 0C 0C
14131837 - MIDI IN [Bome MIDI Translator 2 Virtual In]: B0 2C 46
14131837 - MIDI IN [Bome MIDI Translator 3 Virtual In]: 90 00 00
14131837 - MIDI IN [Bome MIDI Translator 3 Virtual In]: B0 0C 0C
14131837 - MIDI IN [Bome MIDI Translator 3 Virtual In]: B0 2C 46
14131837 - MIDI IN [Bome MIDI Translator 4 Virtual In]: 90 00 00
14131837 - MIDI IN [Bome MIDI Translator 4 Virtual In]: B0 0C 0C
14131837 - MIDI IN [Bome MIDI Translator 4 Virtual In]: B0 2C 46
14132237 - MIDI OUT [Bome MIDI Translator 1 Virtual Out]: 90 00 7F
14132237 - MIDI OUT [Bome MIDI Translator 2 Virtual Out]: 90 00 7F
14132237 - MIDI OUT [Bome MIDI Translator 3 Virtual Out]: 90 00 7F
14132237 - MIDI OUT [Bome MIDI Translator 4 Virtual Out]: 90 00 7F
14132357 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 0C
14132357 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 06
14132357 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 00
14132357 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 07
14132357 - MIDI OUT [COM10]: B0 48 00
14132357 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 01
14132357 - MIDI OUT [COM10]: B1 48 00
14132357 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 02
14132357 - MIDI OUT [COM10]: B2 48 00
14132357 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 03
14132357 - MIDI OUT [COM10]: B3 48 00
14132357 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 04
14132357 - MIDI OUT [COM10]: B4 48 00
14132357 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 05
14132357 - MIDI OUT [COM10]: B5 48 00
14132357 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 06
14132357 - MIDI OUT [COM10]: B6 48 00
14132357 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 07
14132357 - MIDI OUT [COM10]: B7 48 00
14132357 - MIDI IN [Bome MIDI Translator 2 Virtual In]: B0 0C 0C
14132357 - MIDI IN [Bome MIDI Translator 2 Virtual In]: B0 2C 06
14132357 - MIDI IN [Bome MIDI Translator 3 Virtual In]: B0 0C 0C
14132357 - MIDI IN [Bome MIDI Translator 3 Virtual In]: B0 2C 06
14132357 - MIDI IN [Bome MIDI Translator 4 Virtual In]: B0 0C 0C
14132357 - MIDI IN [Bome MIDI Translator 4 Virtual In]: B0 2C 06
14132627 - MIDI IN [Bome MIDI Translator 1 Virtual In]: 90 00 00
14132627 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 0C
14132627 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 46
14132627 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 00
14132627 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 47
14132627 - MIDI OUT [COM10]: B0 48 7F
14132627 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 01
14132627 - MIDI OUT [COM10]: B1 48 7F
14132627 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 02
14132627 - MIDI OUT [COM10]: B2 48 7F
14132627 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 03
14132627 - MIDI OUT [COM10]: B3 48 7F
14132627 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 04
14132627 - MIDI OUT [COM10]: B4 48 7F
14132627 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 05
14132627 - MIDI OUT [COM10]: B5 48 7F
14132627 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 06
14132627 - MIDI OUT [COM10]: B6 48 7F
14132627 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 07
14132627 - MIDI OUT [COM10]: B7 48 7F
14132627 - MIDI IN [Bome MIDI Translator 2 Virtual In]: 90 00 00
14132627 - MIDI IN [Bome MIDI Translator 2 Virtual In]: B0 0C 0C
14132627 - MIDI IN [Bome MIDI Translator 2 Virtual In]: B0 2C 46
14132627 - MIDI IN [Bome MIDI Translator 3 Virtual In]: 90 00 00
14132627 - MIDI IN [Bome MIDI Translator 3 Virtual In]: B0 0C 0C
14132627 - MIDI IN [Bome MIDI Translator 3 Virtual In]: B0 2C 46
14132627 - MIDI IN [Bome MIDI Translator 4 Virtual In]: 90 00 00
14132627 - MIDI IN [Bome MIDI Translator 4 Virtual In]: B0 0C 0C
14132627 - MIDI IN [Bome MIDI Translator 4 Virtual In]: B0 2C 46
14133027 - MIDI OUT [Bome MIDI Translator 1 Virtual Out]: 90 00 7F
14133027 - MIDI OUT [Bome MIDI Translator 2 Virtual Out]: 90 00 7F
14133027 - MIDI OUT [Bome MIDI Translator 3 Virtual Out]: 90 00 7F
14133027 - MIDI OUT [Bome MIDI Translator 4 Virtual Out]: 90 00 7F
14133137 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 0C
14133137 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 06
14133137 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 00
14133137 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 07
14133137 - MIDI OUT [COM10]: B0 48 00
14133137 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 01
14133137 - MIDI OUT [COM10]: B1 48 00
14133137 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 02
14133137 - MIDI OUT [COM10]: B2 48 00
14133137 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 03
14133137 - MIDI OUT [COM10]: B3 48 00
14133137 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 04
14133137 - MIDI OUT [COM10]: B4 48 00
14133137 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 05
14133137 - MIDI OUT [COM10]: B5 48 00
14133137 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 06
14133137 - MIDI OUT [COM10]: B6 48 00
14133137 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 07
14133137 - MIDI OUT [COM10]: B7 48 00
14133137 - MIDI IN [Bome MIDI Translator 2 Virtual In]: B0 0C 0C
14133137 - MIDI IN [Bome MIDI Translator 2 Virtual In]: B0 2C 06
14133137 - MIDI IN [Bome MIDI Translator 3 Virtual In]: B0 0C 0C
14133137 - MIDI IN [Bome MIDI Translator 3 Virtual In]: B0 2C 06
14133137 - MIDI IN [Bome MIDI Translator 4 Virtual In]: B0 0C 0C
14133137 - MIDI IN [Bome MIDI Translator 4 Virtual In]: B0 2C 06
14133407 - MIDI IN [Bome MIDI Translator 1 Virtual In]: 90 00 00
14133407 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 0C
14133407 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 46
14133407 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 00
14133407 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 47
14133407 - MIDI OUT [COM10]: B0 48 7F
14133407 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 01
14133407 - MIDI OUT [COM10]: B1 48 7F
14133407 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 02
14133407 - MIDI OUT [COM10]: B2 48 7F
14133407 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 03
14133407 - MIDI OUT [COM10]: B3 48 7F
14133407 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 04
14133407 - MIDI OUT [COM10]: B4 48 7F
14133407 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 05
14133407 - MIDI OUT [COM10]: B5 48 7F
14133407 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 06
14133407 - MIDI OUT [COM10]: B6 48 7F
14133407 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 07
14133407 - MIDI OUT [COM10]: B7 48 7F
14133407 - MIDI IN [Bome MIDI Translator 2 Virtual In]: 90 00 00
14133407 - MIDI IN [Bome MIDI Translator 2 Virtual In]: B0 0C 0C
14133407 - MIDI IN [Bome MIDI Translator 2 Virtual In]: B0 2C 46
14133407 - MIDI IN [Bome MIDI Translator 3 Virtual In]: 90 00 00
14133407 - MIDI IN [Bome MIDI Translator 3 Virtual In]: B0 0C 0C
14133407 - MIDI IN [Bome MIDI Translator 3 Virtual In]: B0 2C 46
14133407 - MIDI IN [Bome MIDI Translator 4 Virtual In]: 90 00 00
14133407 - MIDI IN [Bome MIDI Translator 4 Virtual In]: B0 0C 0C
14133407 - MIDI IN [Bome MIDI Translator 4 Virtual In]: B0 2C 46
14133807 - MIDI OUT [Bome MIDI Translator 1 Virtual Out]: 90 00 7F
14133807 - MIDI OUT [Bome MIDI Translator 2 Virtual Out]: 90 00 7F
14133807 - MIDI OUT [Bome MIDI Translator 3 Virtual Out]: 90 00 7F
14133807 - MIDI OUT [Bome MIDI Translator 4 Virtual Out]: 90 00 7F
14133927 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 0C
14133927 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 06
14133927 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 00
14133927 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 07
14133927 - MIDI OUT [COM10]: B0 48 00
14133927 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 01
14133927 - MIDI OUT [COM10]: B1 48 00
14133927 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 02
14133927 - MIDI OUT [COM10]: B2 48 00
14133927 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 03
14133927 - MIDI OUT [COM10]: B3 48 00
14133927 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 04
14133927 - MIDI OUT [COM10]: B4 48 00
14133927 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 05
14133927 - MIDI OUT [COM10]: B5 48 00
14133927 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 06
14133927 - MIDI OUT [COM10]: B6 48 00
14133927 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 07
14133927 - MIDI OUT [COM10]: B7 48 00
14133927 - MIDI IN [Bome MIDI Translator 2 Virtual In]: B0 0C 0C
14133927 - MIDI IN [Bome MIDI Translator 2 Virtual In]: B0 2C 06
14133927 - MIDI IN [Bome MIDI Translator 3 Virtual In]: B0 0C 0C
14133927 - MIDI IN [Bome MIDI Translator 3 Virtual In]: B0 2C 06
14133927 - MIDI IN [Bome MIDI Translator 4 Virtual In]: B0 0C 0C
14133927 - MIDI IN [Bome MIDI Translator 4 Virtual In]: B0 2C 06
14134187 - MIDI IN [Bome MIDI Translator 1 Virtual In]: 90 00 00
14134187 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 0C
14134187 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 46
14134187 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 00
14134187 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 2C 47
14134187 - MIDI OUT [COM10]: B0 48 7F
14134187 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 01
14134187 - MIDI OUT [COM10]: B1 48 7F
14134187 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 02
14134187 - MIDI OUT [COM10]: B2 48 7F
14134187 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 03
14134187 - MIDI OUT [COM10]: B3 48 7F
14134187 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 04
14134187 - MIDI OUT [COM10]: B4 48 7F
14134187 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 05
14134187 - MIDI OUT [COM10]: B5 48 7F
14134187 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 06
14134187 - MIDI OUT [COM10]: B6 48 7F
14134187 - MIDI IN [Bome MIDI Translator 1 Virtual In]: B0 0C 07
14134187 - MIDI OUT [COM10]: B7 48 7F
14134187 - MIDI IN [Bome MIDI Translator 2 Virtual In]: 90 00 00
14134187 - MIDI IN [Bome MIDI Translator 2 Virtual In]: B0 0C 0C
14134187 - MIDI IN [Bome MIDI Translator 2 Virtual In]: B0 2C 46
14134187 - MIDI IN [Bome MIDI Translator 3 Virtual In]: 90 00 00
14134187 - MIDI IN [Bome MIDI Translator 3 Virtual In]: B0 0C 0C
14134187 - MIDI IN [Bome MIDI Translator 3 Virtual In]: B0 2C 46
14134187 - MIDI IN [Bome MIDI Translator 4 Virtual In]: 90 00 00
14134187 - MIDI IN [Bome MIDI Translator 4 Virtual In]: B0 0C 0C
14134187 - MIDI IN [Bome MIDI Translator 4 Virtual In]: B0 2C 46
14134587 - MIDI OUT [Bome MIDI Translator 1 Virtual Out]: 90 00 7F
14134587 - MIDI OUT [Bome MIDI Translator 2 Virtual Out]: 90 00 7F
14134587 - MIDI OUT [Bome MIDI Translator 3 Virtual Out]: 90 00 7F
14134587 - MIDI OUT [Bome MIDI Translator 4 Virtual Out]: 90 00 7F
14134707 - MIDI OUT [COM10]: B0 48 00
14134707 - MIDI OUT [COM10]: B1 48 00
14134707 - MIDI OUT [COM10]: B2 48 00
14134707 - MIDI OUT [COM10]: B3 48 00
14134707 - MIDI OUT [COM10]: B4 48 00
14134707 - MIDI OUT [COM10]: B5 48 00
14134707 - MIDI OUT [COM10]: B6 48 00
14134707 - MIDI OUT [COM10]: B7 48 00
ibanman555
2016-10-10 23:16:20
2016-10-10 23:23:12
ibanman555
2016-10-10 23:27:25
ibanman555
2016-12-11 21:43:50
2016-12-15 12:46:13
CreepyPants
2016-12-16 16:34:16
2016-12-19 10:01:52
ibanman555
2016-12-19 16:54:42
ibanman555
2017-01-05 20:21:49
ibanman555
2017-01-05 22:35:14
2017-01-29 15:53:49
ibanman555
2017-01-30 01:02:23
2017-04-12 23:00:37
ibanman555
2017-04-13 00:08:30
