apc 40 mk2 ableton
lucass.victorino
2016-10-07 00:58:15
hello, guys.
I'm new at Bome translator, so maybe my problem will be like piece of cake for you. However, I'm trying FOR HOURS to achieve the following:
the midi message coming from the APC 40 mk2's foot switch turns on the session record. I've already made the message translation and it now does what I want... but it still switch on the session record button!
what should I do?
thanks!!!
ableton 9.6.1
bome 1.8.1
mac osx 10.11.5
gabriels
2016-10-09 05:40:34
Hi Lucass,
Look at the top of the right pane (the Translator window) . Under "Incoming". There's a checkbox for "Swallow MIDI message, do not pass on to rounted ports". I think if it isn't checked you might be passing the original message to Ableton.
Gabriel
