caps lock
pdave
2006-01-05 06:36:05
I noticed the outgoing keystrokes are always capital letters. Is there a way to make them lowercase? I noticed because with Ableton live 5.0 the software gets funny if I don't remember to put my caps lock on, so the keystrokes will always be the capital letters.
Thank you!
Parixit
-ps....your midi translator is such a great lil tool!
2006-01-05 12:58:41
What you enter in Midi Translator is not "letters", but keys. So in order to produce a capital A, press Shift and A simultaneously in the edit field in Midi Translator. You'll see a display of "Shift(A)" to denote a key combination. With the same scheme you can create any number of key combinations.
