execute translator if
xbenedict
2016-11-06 02:25:53
Hello
I want to use the pitchbend as a modwheel (it is working fine, i made all the translators) but i want this to happen ONLY when the key A0 is pressed, i have no idea how to do that,,,, help is much appreciated
Sakis
2016-11-07 12:39:51
Do you mean while the key is pressed? If not you need to set a second key to disable pitchbend to mod wheel.
It's easy on both cases. A simple approach is making 2 different presets inside the project and set a trigger on A0 note to enable the preset pitch->mod as an outgoing action.
2016-11-07 23:09:34
Hi xbenedict,
Sakis approach is probably the easiest, but we know how difficult the first steps can be. Let us know if you need more in-depth guidance!
Best,
