2016-11-18 11:35:07
A user asked:
I have kind of a unique situation. I am trying to build a new script for my Vestax VCM-600 using Remotify.io. The problem is the controller outputs the same numbers on different MIDI channels (ex. fader 1 MIDI channel 1 and fader 2 MIDI channel 2 both = cc#69) and this causes error messages in Remotify. I need to change CC values in order to avoid repeated numbers on multiple midi channels in order to create this script.
The question is with MIDI Translator will I be able to simply change numbers around and if so will it interfere with my other MIDI controllers or my new Remotify script? Also, is this a function that will require Pro version of Bome MIDI Translator?
