Kulu Orr
2016-11-19 14:46:39
I've been using the excellent BMT for years now on a PC to control all the other software I use during my shows (lighting control program, several Java modules I've written to control video and animation projection, Ableton Live etc.) using a different MIDI virtual port to communicate with each program.
Oddly, after switching to Mac, Ableton shows the virtual ports opened in BMT, but other programs do not.
If I create an "IAC virtual port" using the OSx "Audio MIDI Setup" utility, it shows up in both BMT and the destination program (QLC+ lighting control) and I can use it to communicate with it, however the original virtual ports do not appear, and even when I route them (in the BMT router) to the IAC port that does work, no signal arrives at the destination program.
Should I just abandon the BMT virtual ports and rewrite all the translators to communicate through the IAC ports? Is there some performance related issue here that I should be aware of?
Kulu
Kulu
