sameloop
2016-12-03 15:36:37
Hi. I'm having a few problems, as a new and not very mathematically minded user of MT Pro.
Here's the ideal setup I want to achieve:
Ableton Live 9 and Magic (VJ software) running simultaneously and both controlled by the Ableton Push 2. Magic is fully MIDI controllable and so I wish to have a setup where I can, for instance, have a knob controlling the filter on a synth and a parameter in a Magic module at the same time, to match visuals with sound, or hit a note that has a sample on it and change a picture etc.
Basically, I think I can achieve this with other controllers (for instance, my Novation Launchkey), but I want to use the Push, because it is a better piece of hardware for live use (I'll be gigging this eventually, with the visuals projected).
The Push (as you may know) has two operating modes, the standard one, which is full duplex link to Live 9 with all the functions and synced display, and the other is 'User Mode', which just lets it operate as a generic controller. I'd rather use it in the former mode, ideally, but if I had to use it in User Mode, it wouldn't be a massive issue, all I want is the aforementioned setup to work.
My problem with the Push is the rotary encoders. They are infinite, accelerated and touch sensitive and as well as transmitting continuous controller data, they transmit a note on at a fixed pitch when touched (and note off when released). I'm not sure of the reason for this, but there it is. Anyway, this seems to mean that unless you are using them in Live, they transmit only the note, plus a value of 1 or 127 when turned either way. I want them to behave like a standard absolute controller and without the note message.
I've read a couple of answers on here dealing with this type of thing, but I couldn't get them to work:
forums/viewtopic.php?t=2036
forums/viewtopic.php?f=3&t=3517
This is mainly because I have a hard time getting my head around the way the software works and having a clue what to troubleshoot if things don't work. I'm sure it's easy if you know how!
Anyway, I would be really, really grateful for any help as I'm going a bit insane!
All the best, Sam.
All the best, Sam.
