godelbrot
2016-12-08 18:56:54
Hi there, I am contemplating purchase but I need to be sure it can do what I want.
Basically I want to have a "Power Knob" and a "Power Button" that I can map macro controls to on the fly both on my hardware synths and for internal ableton audio effects.
The idea is that I can have two launchpads, one for analog (knob controlled) parameters, and one for button triggers. If let's say I want to be able to do a build up, I want to be able to select my moog's filter cutoff, my minilogues filter envelope decay and noise source, the volume of the snare on my tr8, and the delay amount on my VolcaFM, all just by touching buttons on the launchpad. These parameters are all then immediately mapped to my "Power knob", and I can control them all in a giant sweep without having 8 arms. I can then have a clear button that erases all these mappings and I can build up another.
The same goes for buttons. If, after my buildup, I want to have a drop where a particular sample is triggered, my TB-3 volume is unmuted, and the kick drum on my tr8 is also unmuted, I just select those parameters on the other launchpad and they are immediately mapped to my "power button" so I can trigger these all at the same time without being an octopus.
It's essentially live midi-mapping as a performance tool.
Is such a thing possible in this software?
