Hi dirtyHeaven,
sorry for the VERY late response. We've been swamped...
If the pads always send in the order, it's quite simple with MT.
Let's assume that it first sends Note On with velocity, then CC position x, then CC position y, then pressure.
Now you want to ignore the note velocity, and defer the Note message until after the control change, using the y position.
Then create these translators (schematic):
- Incoming: Note On, set g0 to note number.
Outgoing: none (swallow)
- Incoming: Note Off, any note.
- Incoming: CC position Y, set pp to value.
Outgoing: CC position Y, value: pp (pass through)
Outgoing: Note On, note: g0, velocity: pp
- Incoming: CC position Y, any value.
Outgoing: Note Off, note: g0, velocity: 0
The "swallow" checkbox must be checked for ALL incoming actions!
For passing the CC position X and the pressure messages, use the MIDI Router. We "manually" route the CC position Y so that we ensure that the CC is sent before the Note On. I also assume that the pads send instantaneous drum notes only, where Note On is immediately followed by Note Off and there cannot be overlapping notes. If that's not true, it's possible to enhance the preset, but it will need a little more logic.
If that doesn't work, please include a log of the Log Window in MT Pro -- having activated ALL checkboxes including timestamp.
